chevytuck95 Posted November 25, 2010 Report Posted November 25, 2010 If they used an xpress kit it will not turn on untill the module see's 32 degrees 1995 Honda Accord Coupe still building only thing done is big three and one run of stinger 0 gauge. Feedback
kickass audio Posted November 25, 2010 Author Report Posted November 25, 2010 Ohh ok. Yea my viper read at 41 when I programmed it. So I hope that I didn't screw it up when I programmed it. But ill call the shop to confirm they used an xpress kit and see for sure. I didn't know the xpress kits had a temp gauge inside themselves. I thought it was just in my vipers brain. But ill find out for sure. Thanks again bro!! 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
chevytuck95 Posted November 25, 2010 Report Posted November 25, 2010 Yes the module senses the temp on its own. It makes it so it can be used with cheap alarms to the expensive ones. I would have used an XK-01 Module on your vehicle it does rear defrost automatically and only need to hook up my D2D plug, ignition wire and data. Then a quick turn of the ignion and done. I really like xpress kit but would like to get into idatalink i''ve heard a lot of good things about them. I install Astro Starts personally 1995 Honda Accord Coupe still building only thing done is big three and one run of stinger 0 gauge. Feedback
kickass audio Posted November 25, 2010 Author Report Posted November 25, 2010 From what my receipt says it reads of the model being ads-alca 64 and the make as an idatalink. But they charged me an additional fee of $40 for the hookup. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
chevytuck95 Posted November 26, 2010 Report Posted November 26, 2010 I'm not entirely sure on those idatalink's so not sure if it also does internal temp or is based off the main brains temp. 1995 Honda Accord Coupe still building only thing done is big three and one run of stinger 0 gauge. Feedback
kickass audio Posted November 26, 2010 Author Report Posted November 26, 2010 from what i read on their install manual for the idatalink its either off the onboard thermostat on the idatalink that will turn it on when its colder than 32 degrees Fahrenheit, or you can put a switch on it and when you start it up remotely it will turn it on regardless of the temp. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
