craniumcrackinbassv2 Posted November 25, 2010 Report Posted November 25, 2010 if i build a sealed box for 2 15's and im not happy with it can i convert it into an aeroport?
fritosaregood Posted November 25, 2010 Report Posted November 25, 2010 if i build a sealed box for 2 15's and im not happy with it can i convert it into an aeroport? depends on the airspace you build the box too, Usually just the sealed box wont have the volume you need to make it ported, and even if you did build it just big enough, you would need the port to be external so it wouldnt take up more space inside the box. seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
MrSkippyJ Posted November 25, 2010 Report Posted November 25, 2010 I just changed mine, but also changed subs. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
craniumcrackinbassv2 Posted November 25, 2010 Author Report Posted November 25, 2010 so im better off just going ported lol
nCOMP1337 Posted November 25, 2010 Report Posted November 25, 2010 probably, i have a friend with a similar situation, he has a sealed box that is larger than the recommended specs for a ported box for the particular subs, so he is debating whether to add in a port, since the sealed enclosure is larger than the ported one needs to be
