SnowDrifter Posted November 27, 2010 Report Share Posted November 27, 2010 When using a circle jig like the one made by Jasper, do I need to take into account the size of the bit that I am using? Like... Say I want to cut a 5" hole, and my bit is 1/4", would I set the jig to 4 7/8" to compensate? Or no? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted November 27, 2010 Report Share Posted November 27, 2010 The Jasper 200 is set to use with a 1/4 inch bit so no you don't have to compensate. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
SnowDrifter Posted November 27, 2010 Author Report Share Posted November 27, 2010 The Jasper 200 is set to use with a 1/4 inch bit so no you don't have to compensate. What if I use a different sized one, like say a larger one to cut down on the number of passes for a flush-mount hole? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted November 27, 2010 Report Share Posted November 27, 2010 Then you'd have to account for the diameter of the new bit minus 1/4" for the standard. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
SnowDrifter Posted November 28, 2010 Author Report Share Posted November 28, 2010 How about the Jasper 400, like for if I need to cut holes for tweets? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
bumonskateboard6 Posted November 28, 2010 Report Share Posted November 28, 2010 How about the Jasper 400, like for if I need to cut holes for tweets? I have one but haven't messed around with it yet so I'm not sure, I just get a hole saw bit for a drill they have them from 1-3 inches usually Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also? Link to comment Share on other sites More sharing options...
neuspeedescort Posted December 12, 2010 Report Share Posted December 12, 2010 if you are using a jasper 200 and run a bit larger then 1/4" you will end up cutting a new hole in your jig. its specifically sized for a 1/4" bit to plunge thru it. from there you will have to take 1/2 the diameter difference and account for that properly. NEUMAN Link to comment Share on other sites More sharing options...
