yeah lol get the max length width and height you can lol
not as simple
R.I.P!
(Nov-29-2009)
92 explorer
current build
please take into acct any openings etc so you wont be like me today pulling out your entire backseat and using a big ass hammer to make your box fit.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
lol thats why i asked, i have an 08 tsx, the trunks pretty big for a sedan IMO...but im trying to fit 2 SA15's in a ported box and im worried about the box being so big that it messes with the air flow...
A very easy thing to do is make a mock-up of the box. Measre the trunk and openings to see what size box you think you can fit. Figure out what size the box needs to be based on those specs. Get some cardboard and fab up a box the same size as the one you intend to build. Just use some tape to hold it together. It dosent have to be pretty just needs to be the correct size. Then try and fit the thing in your trunk thru the lid or thru the rear seat opening. If it fits your golden, if it dosent figure out what adjustments need to be made and try again.
you could have a a huge trunk but have a small opening making it hard to get a big box in there you may have to build inside the trunk
i recently built a box for a customer and didnt think bout that when designing box and ended up having to cut the port off and using aeros to get the box to fit
but OP measure trunk opening if you have arms on the side of trunk that hold it up measure in between them, assuming you have those you'll have those bars to take the weight off the trunk and make it easier to lift.... measure the height of that while the trunks closed
other then that just measure your max dimensions that will allow you fit the box in vehicle
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1172 Guests (See full list)
