Hey got a 94 Cadillac Deville with nearly 100k. The car was having some issues about a month ago. The car would idle odd and jump around. Took it to a mechanic and he said the idle speed control sensor is no longer working. Replaced it.Also was having a leaky water pump gasket and radiator. Had the idle control sensor, the water pump plus gasket and the radiator. Now it runs a little better, but seems to idle a little too low, car has very little power, is extra loud and gets crappy gas mileage. Mechanic said it could either be the catalytic converter or the throttle body being dirty, but no leaky exhaust pipe "maybe thought it was loud because of that". Cleaned the throttle body real good, helped a little but still has the same issues. I was told the catalytic converter would smell like poo if it was too clogged.
I could adjust the idle control sensor a little to make it idle a little more, but not sure if its gonna do any good. But has anyone had similar issues and maybe a quick fix or just a reliable fix ??
If your car is running rough and feels bogged down, most likely your catalytic converter is clogged up. There should be a screw on the throttle body to adjust the idle of your car.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Could be the cat, you could also change the spark plugs and wires if you haven't.
thats what i was thinking too but would it happen so quickly ? its like it was running great then suddenly like poo... same with the catalytic converter ?
If the cat is clogged it will run like complete crap. If the plugs and wires haven't been changed also it can run like crap.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
Have a mechanic check the cat for you. Or you can do it yourself.
Do the 'Drill Test' to check for clogged cat:
DRILL TEST – CLOGGED CATALYTIC CONVERTER
The PCM does a very good job of monitoring the efficiency of the cat; that is, whether it is effectively cleaning pollutants from the exhaust stream.
But a cat can become partially-clogged in several ways, including exhaust deposits and collapse of the honeycomb structure; it is still able to pass exhaust gases, and may even be ‘efficient’ at cleaning them.
But the clog creates excessive backpressure that adversely affects the engine performance.
This is primarily noticeable as lack of power at higher rpms (3500+) and acceleration, and as a rough idle that may even cause stalling; at mid-range (1000-3500) the backpressure is still present, but not noticeable since the strong engine kind of ‘powers through’ the clog.
TEST:
A mechanic has a special $200 tool that he will screw into the front O2S port, to measure the actual speed of exhaust gases past that point; very definitive test.
Midas or other muffler shop will take a torch and burn a 3/8” hole in the side of the exhaust pipe, about 4 inches (100mm) ahead of the cat, toward the engine. This is enough to relieve the pressure AT IDLE and allow the crappy idle to smooth out noticeably.
The DIYer can do the same thing by drilling 3/16” (4mm) hole at the same location; larger would be better, but 3/16” (#14) is the largest commonly-available sheet metal screw for sealing the hole.
With the engine idling, alternately open and close the hole using an oven mitt.
* If the idle improves with the hole ‘open’, then the cat is clogged and needs replacement.
* If there’s no difference between ‘open’ and ‘closed’, clogging is not the issue; seal the hole with the screw (Midas would burn the hole shut with a torch).
Derp.
