or you could have what i had on my 98deville a vacum leak in the throttle body or the gaskets for the air intake
you know what that might be it... where was it leaking from specifically ? you know the gasket that last on top of the throttle body that connects to the plastic air intake ? Its no longer there... but its a tight fit.. thought it wouldn't matter... hmmmmm thanks
I would check your plugs and catalytic converter 1st then look at the vacuum lines
Sounds to me like a combo of clogged cat and fouled plugs
Team MaxRetribution
Si Vis Pacem Parabellum
Well an update.....
Tried the catalytic converter trick... and it sorta worked !! I only had limited drill bits and honestly not sure of the size of it "about the size of a BB". Although i did the oven mitt trick it didn't do anything different. It did start easier and drove better.. but when idling it didn't do any different. Car has a little more power, but when taking off from a dead stop it still stutters. Guess I will update once the catalytic converter is replaced.
Does it shake when you idle or give it gas? If so I'd say fouled plug, best to do a tune up at 100k anyways if it's never had one. Just my .02 :good: good luck and hope it gets fixed :drinks:
My F-150 Build (So Far)
2 DC L3 10's
Kenwood KDC-X794
(4) Selenium ST200 (Highs)
(2) RE X8 (Mids)
Sundown Sub/Mid/High Amps
Shuriken Batteries
Knu Wiring
My Feedback Thread
yeah... it almost stalls "sometimes does but rarely"... someone thing it could be low idle ? my girl thinks it is.. OH and she's totally not a certified mechanic or anything like that.
and i'm getting a tune up for it... i read its due at 100k and i've had it since 60,xxx and haven't done it yet.
yes go to dealership and get that gasket tight fit or silcone will not work eighter trust me it was like 8 bucks for my gasket so yours should be the same also if your car is stalling when pressing on gas it is your plugs or wires good luck the shaken off ur car is from that gasket and the plugs or wires you gotta take one problem out at a time till its how you want it "money" the key word bro i put like 4 grand in my car with engine and rebuild tranny runs perfect now :drinks:
Edited by felipe82
