best way to cover a speaker pod in vinyl ???
i made some speaker pods for my doors and they are attached to a panel for the bottom of the door .... what is the easiest way to cover them in vinyl ??? doesnt like to stretch very easily and contour to the curves
Im sure you could make it happen, might take a little bit longer. Ive used a hair dryer to heat up vinyl decals and it worked good
My F-150 Build (So Far)
2 DC L3 10's
Kenwood KDC-X794
(4) Selenium ST200 (Highs)
(2) RE X8 (Mids)
Sundown Sub/Mid/High Amps
Shuriken Batteries
Knu Wiring
My Feedback Thread
x2 use heat but be careful. and when you glue it spray both surfaces and let it sit for a bit to get tacky then apply the vinyl. if you spray it then immediately put it on youre going to have trouble getting it to stick
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
ok thank you guys !! much help going to go try it now once im done sanding little bit more !!!!
should i cover the pod in bondo and sand before covering in vinyl or can i just cover the fiberglass ??? also would the bondo give more strength to the pod ?
Every imperfection shows in vinyl so bondo over the fiberglass and sand smooth. The more solid the better when it comes to pods, thick is good.
Team DC/Team DEFJ
2003 Chevy Tahoe
Kenwood DDX 719
Rockford Fosgate 3Sixty.3
2 DC Audio Full Carbon LVL6 M2 18's
4 Rockford Fosgate T2500bdcp's
1000-4
600-4
5 Sets Rockford T3 Components
Ipad Dash
My Youtube Page
  • Who's Online   1 Member, 0 Anonymous, 907 Guests (See full list)
