mast240 Posted March 10, 2011 Report Posted March 10, 2011 ^^^^^ very sick bro!!!! you dont see many bagged minivans out there... i'll post some pics of mine after the rebuild this weekend, but heres a list of what i've got 1999 montero sport contitech 2500's up front and 2600's in rear (being changed to slam specialists) ARP 1/2" air engine (FBSS) VIAR 350c compressor (adding another one soon) 7 gallon tank 2 viar dual needle gauges and 10 switch box current build: 99 bagged montero sport subs: 4 AQ HDC3 18's, walled in a clamshell box amps: subs- 2 modded AQ 2200's, running 2550 at 1 ohm each components: (rf p1 8:(midbass), 2 cadence cwm 6.5, memphis pr 6.5 coax)- each door HU: android galaxy tablet, Kenwood KVT-516 2/0 gauge ran all around 6 optima red tops (will be updated, i get them DIRT cheap) keeping my fingers crossed for membership into the 160 db club! MY BUILD LOG MY YOUTUBE CHANNEL (SUBSCRIBE!)
ChampN252 Posted March 10, 2011 Report Posted March 10, 2011 First, that Bel-air is badass. When dropping a pick-up does it have to have that hump in the back like minitruck's? (nice truck btw) I would love full size pickup like a F150 or 1500 on airbags with a blowthru, but I starting to doubt that can be done now. 2012 Honda Accord Radio: Pioneer AVH-4200NEX
mast240 Posted March 10, 2011 Report Posted March 10, 2011 First, that Bel-air is badass. When dropping a pick-up does it have to have that hump in the back like minitruck's? (nice truck btw) I would love full size pickup like a F150 or 1500 on airbags with a blowthru, but I starting to doubt that can be done now. if you want it to tuck the back wheels it does. you can do without it, and just drop the back end... but it wont be that low... maybe 4" lower than normal. but the reason for the tub job on the bed is in order to lay frame, you have to notch the frame... otherwise, your frame will end up laying on top of you axle, without that much of a drop. as far as doing an f150 or 1500... its completely possible... it's already been done SOOOO many times, that it should be fairly easy to find parts for it current build: 99 bagged montero sport subs: 4 AQ HDC3 18's, walled in a clamshell box amps: subs- 2 modded AQ 2200's, running 2550 at 1 ohm each components: (rf p1 8:(midbass), 2 cadence cwm 6.5, memphis pr 6.5 coax)- each door HU: android galaxy tablet, Kenwood KVT-516 2/0 gauge ran all around 6 optima red tops (will be updated, i get them DIRT cheap) keeping my fingers crossed for membership into the 160 db club! MY BUILD LOG MY YOUTUBE CHANNEL (SUBSCRIBE!)
sully Posted March 10, 2011 Report Posted March 10, 2011 First, that Bel-air is badass. When dropping a pick-up does it have to have that hump in the back like minitruck's? (nice truck btw) I would love full size pickup like a F150 or 1500 on airbags with a blowthru, but I starting to doubt that can be done now. You don't have to cut into the bed but you will not be able to lay frame with large wheels if you don't. I raised the bed floor and added the notch and wheel wells to be able to lay body on 26's but with smaller wheels and not needing to lay frame it can easily be done. A mini notch and cutting away some of the inner wheel well will be sufficient for a basic setup. Here is how my bed ended up: 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
doug118 Posted March 13, 2011 Report Posted March 13, 2011 OR do an underslung setup and have a full bed minus the wheel wells. Underslung means instead of having a c-notch, the frame is built under the axle to give you a really clean bed. the downfall is you can't get as much lift 2001 Tahoe. Huge front stage and 55+ substage http://www.stevemeadedesigns.com/board/topic/196418-another-tahoe-build-huge-front-stage-and-155-substage/
mast240 Posted March 22, 2011 Report Posted March 22, 2011 ^^^^^ bro... that frame is sick!! is that all stainless or chrome molly or some shit?? current build: 99 bagged montero sport subs: 4 AQ HDC3 18's, walled in a clamshell box amps: subs- 2 modded AQ 2200's, running 2550 at 1 ohm each components: (rf p1 8:(midbass), 2 cadence cwm 6.5, memphis pr 6.5 coax)- each door HU: android galaxy tablet, Kenwood KVT-516 2/0 gauge ran all around 6 optima red tops (will be updated, i get them DIRT cheap) keeping my fingers crossed for membership into the 160 db club! MY BUILD LOG MY YOUTUBE CHANNEL (SUBSCRIBE!)
lowrthnu92 Posted March 23, 2011 Report Posted March 23, 2011 I so bad want to notch and body drop my excursion with the 30s! that's just too much for me right now. Maybe next winter I will lol Do It !!!!!!! hes on 26s My truck
mast240 Posted March 24, 2011 Report Posted March 24, 2011 here's a video of mine... even tho its already been posted... might as well post it on this thread ( call me a post whore all you want) current build: 99 bagged montero sport subs: 4 AQ HDC3 18's, walled in a clamshell box amps: subs- 2 modded AQ 2200's, running 2550 at 1 ohm each components: (rf p1 8:(midbass), 2 cadence cwm 6.5, memphis pr 6.5 coax)- each door HU: android galaxy tablet, Kenwood KVT-516 2/0 gauge ran all around 6 optima red tops (will be updated, i get them DIRT cheap) keeping my fingers crossed for membership into the 160 db club! MY BUILD LOG MY YOUTUBE CHANNEL (SUBSCRIBE!)
BAGGEDBIRDS.com Posted March 26, 2011 Report Posted March 26, 2011 same old car Slam 6" all 4 corners 2 gallon tank SMC 3/8" valves 1 small compressor 3/8" line its been bagged 10 years, same compressor, valves, and plastic air line. 1st SMD "System of the Month" Feb. 2007 Zapco Studio 500 (2) Zapco Studio 300X Zapco Studio 204 (2) (2) FI 12ssd's w/ copper coils DLS Iridium Tweeters DLS UR2.5 MidRange FI. N.7 Midbass JL Audio TWK 88 Mechman 370A Elite Alternator
