AcIdBuRn02ZTS Posted November 21, 2012 Author Report Posted November 21, 2012 With me doing all the fabrication and labor, Parts cost set me back just under 5k Major setbacks where the trans adapter and flexplate I got from destroked.com... they dont mention that the 4l60e trans changed when the ls based engines started being used... ended up costing me transmission number 1.. had to swap to an earlier trans (fround a rebuild one near my home town for a couple hundred) Most of the suck factor came from wiring... that and taking the motor in and out of the truck multiple times while building all the mounts. IF I had fundage up front instead of funding it as I could, it would have been done a lot faster. The engine came out of a ups truck... had 60k miles on a cummins reman. You can find these engines in step vans and light commercial trucks, generators, excavators, etc..etc.. figured if it would pull a ups truck down the interstate, it should do just fine in the tahoe... so far so good. However, I will be compound turboing it come spring 4btswaps.com helped me out A LOT along the way... also you can typically find this motor and other smaller displacement diesels in their classifieds section.. or ebay, craigslist, etc... best way to do it is buy a stepvan like an early 90's chevy p30 with the engine in it... the bodys of the vans are aluminum typically so when you pay 2000-2500 for the van, you can scrap the body and make a good bit of your money back if not all of it. Thats what a lot of guys on the 4bt forums do. -Chris 03' Black Z71 Tahoe 3" Lift / 315/70/R17 Goodyear Duratracs Eclipse AVN6620 Touchscreen Head Unit Hifonics BRX3016 - 3krms @ 1ohm 2 RE Auido SX 18s - 14.5^3ft net @ 30hz w/ 200^2in. port120hp Cummins 4bta Swap
Brandon15zzz Posted November 21, 2012 Report Posted November 21, 2012 Awesome thanks. So I seen it only has 120hp does it get up and go or is it more for a gas mileage for you? I have an 02' silverado with the 4.8 I average like 13 Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34 Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
AcIdBuRn02ZTS Posted November 21, 2012 Author Report Posted November 21, 2012 In stock form... its slow off the line but has no problem running 80+mph on the interstate... However... if you check out the 4btswaps.com site... you'll find guys that click off 12 and under in the 1/4 mile... 700+ lb. ft.. southbend clutch built a mud rail that is making over 700hp on the bottle... its a rocket.. it all depends on what you want. It moves ok for me... its big and slow... was with the 5.3 as well... the 5.3 came out of the hole quicker but it also sucked down double the fuel. Once I get my compound turbo setup finished and the 4l80e swapped in, it should run just fine Waiting til friday to order my damp-pro... hopefully there are some good deals to be had. Thanks guys -Chris 03' Black Z71 Tahoe 3" Lift / 315/70/R17 Goodyear Duratracs Eclipse AVN6620 Touchscreen Head Unit Hifonics BRX3016 - 3krms @ 1ohm 2 RE Auido SX 18s - 14.5^3ft net @ 30hz w/ 200^2in. port120hp Cummins 4bta Swap
Brandon15zzz Posted November 22, 2012 Report Posted November 22, 2012 Yea I checked out a few of the build logs and stuff over there. Got to do some reading up. A lot of lingo I don't understand but ill try and learn it. It's got me interested. Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34 Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
Twostrokeking Posted November 22, 2012 Report Posted November 22, 2012 Should duramaxed it (; nice lookin truck. My Truck BuildSpending money on things I don't need, to impress others I don't know.At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
b-eazy Posted November 22, 2012 Report Posted November 22, 2012 Wow .....welcome....and u got one ssssiiiiiicccckkkkk asssss truck....
ibf150 Posted November 23, 2012 Report Posted November 23, 2012 Just curious, how big is the weight difference between the 4bt and the chevy 5.3? I've thought about doing this swap in my F150 but I'm concerned about the IFS My Build Thread 2005 F150 : 2005 F150 Center Console Build Center Console - 3.2 cubes @ 35hz 4 RE Audio SRX10s - Pure Audio 3000.1 8 6.5 Soundstream SME.658 - Soundstream TN4.900D 4 NX-5 Super Tweeters
STEvil Posted November 23, 2012 Report Posted November 23, 2012 4bt are not significantly heavier than a 5.3, they work great. Give the fuel pump some loving and you'll be pushing more horses very easily. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
AcIdBuRn02ZTS Posted November 23, 2012 Author Report Posted November 23, 2012 a few hundred pounds heavier... I didnt notice any extra drop from the weight... Ive tweaked the pump a little A flat tip screw driver is much cheaper then a hand held tuner Got my damplifier pro ordered... time to make it quiet -Chris 03' Black Z71 Tahoe 3" Lift / 315/70/R17 Goodyear Duratracs Eclipse AVN6620 Touchscreen Head Unit Hifonics BRX3016 - 3krms @ 1ohm 2 RE Auido SX 18s - 14.5^3ft net @ 30hz w/ 200^2in. port120hp Cummins 4bta Swap
