n8ball2013 Posted December 11, 2010 Report Posted December 11, 2010 since its like 10 degrees I want remote start. Anyone got a diagram and what bypasses are needed? Figure ill take a peek and see if i have to do the hokey pokey for it. If not Ill throw one in. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Shyne151 Posted December 12, 2010 Report Posted December 12, 2010 They aren't bad at all. xk09s have been working well lately(but you will need to get it flashed). Last year we were doing them with a 556u and a blank circle + key. The xk09 will also take care of all your mux connections, so you don't have to wire in any resistors... it does door locks... ummm pretty much everything. Or you can pick up a pkumux and it will do the mux and cirlce +... then you just need to wire in for the doorlocks... which is nothing special(probably how i would do it). Anyways here is the directwire. 2009 Chevrolet Malibu DirectWire 2.0 Vehicle Information Remote Start Item Wire Color Polarity Wire Location 12 Volts red/black (50A) + BCM, red 41 pin plug (X3), pin D1 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Second 12 Volts red/black (30A), red/black (30A) + BCM, red 41 pin plug (X3), pins D12 and D10 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Starter purple (for starter kill only) + starter or underhood fuse box, white 68 pin plug, pin D12 Second Starter white +9.6K ohms ignition switch, green 6 pin plug, pin 5 If interface module is not available, see Tech Doc 1605. Ignition pink + ignition switch, green 6 pin plug, pin 3 Second Ignition N/A Third Ignition N/A Accessory brown + ignition switch, green 6 pin plug, pin 4 Second Accessory same as second starter +6.3K ohms Third Accessory N/A Keysense same as second starter Data Bus white (resistor code), white/black (5V reference) mux ignition switch, green 6 pin plug, pins 5 and 6 Also found at the BCM, gray 72 pin plug (X2), pins 56 and 62. The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Can Bus High tan/black (high speed GMLAN) data data link connector, black 16 pin plug, pin 6 Can Bus Low tan (high speed GMLAN) data data link connector, black 16 pin plug, pin 14 Can Bus Sw dk. green (low speed GMLAN) data data link connector, black 16 pin plug, pin 1 Also found at the BCM, gray 72 pin plug (X2), pin 55. The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Power Lock white - driver kick or BCM, gray 72 pin plug (X1), pin 66 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Power Unlock same as power lock -1.5K ohms Lock Motor gray/black 5 wire driver kick or BCM, red 41 pin plug (X3), pin A5 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Driver Unlock Motor tan 5 wire driver kick or BCM, red 41 pin plug (X3), pin B1 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Parking Lights (-) brown/white - headlight switch or BCM, gray 72 pin plug (X2), pin 5 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Parking Lights (+) brown + driver kick or BCM, red 41 pin plug (X3), pin A7 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Hazards white - hazard switch or BCM, gray 72 pin plug (X2), pin 9 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Turn Signal (Left) lt. blue/white (F); yellow ® + BCM, gray 72 pin plug (X1), pin 38; red 41 pin plug (X3), pin A9 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Turn Signal (Right) dk. blue/white (F); dk. green ® + BCM, gray 72 pin plug (X1), pin 56; red 41 pin plug (X3), pin A12 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Headlight white - headlight switch or BCM, gray 72 pin plug (X2), pin 15 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. AutoLights purple/white (ground to turn off autolights) - headlight sw or BCM, gray 72 pin plug (X2), pin 17 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Reverse Light lt. green + rear fuse box, white 32 pin plug, pin E4 The rear fuse box is in the left side of the luggage compartment. Left Front Door Trigger gray/black - BCM, gray 72 pin plug (X1), pin 51 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Right Front Door Trigger tan/white - BCM, gray 72 pin plug (X1), pin 72 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Left Rear Door Trigger lt. blue/black - BCM, gray 72 pin plug (X1), pin 54 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Right Rear Door Trigger lt. green/black - BCM, gray 72 pin plug (X1), pin 53 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Dome Supervision gray - BCM, red 41 pin plug (X3), pin A10 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Trunk/Hatch Pin orange/black - BCM, gray 72 pin plug (X1), pin 18 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Rear Glass Pin N/A Hood Pin pink/black - hood switch or BCM, gray 72 pin plug (X1), pin 69 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. On hybrid models, this wire does not go to the BCM, so you need to connect it in the engine compartment. Trunk/Hatch Release brown/white - driver kick or BCM, gray 72 pin plug (X1), pin 71 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Trunk Release Motor tan/white + rear fuse box, black 62 pin plug, pin F10 The rear fuse box is in the left side of the luggage compartment. Fuel Door Release N/A Power Sliding Door (Left) N/A Power Sliding Door (Right) N/A Factory Alarm Arm lt. green - driver kick or BCM, gray 72 pin plug (X1), pin 35 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Meter this wire while turning the key in the driver door key cylinder. Factory Alarm Disarm same as factory alarm arm - 500 ohms Disarm No Unlock Passkey and ignition Trunk Alarm Shunt N/A Tachometer NOT pink or pink/black ac any fuel injector Wait to Start N/A Neutral Safety N/A Clutch Pedal N/A Fuel Pump gray + rear fuse box, black 62 pin plug, pin A10 The rear fuse box is in the left side of the luggage compartment. Rear Defroster white + latched BCM, gray 72 pin plug (X1), pin 57 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Mirror Defroster same as rear defroster Left Front Heated Seat lt. blue/black + driver heated seat switch, black 6 pin plug, pin 3 Right Front Heated Seat lt. blue/black or dk. blue/black + passenger heated seat switch, black 6 pin plug, pin 3 Speed Sense wheel speed sensor Brake Wire white + BCM, gray 72 pin plug (X1), pin 42 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Parking Brake lt. blue - parking brake switch or BCM, gray 72 pin plug (X1), pin 59 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Horn Trigger tan - horn switch or BCM, gray 72 pin plug (X2), pin 14 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Wipers dk. green + BCM, gray 72 pin plug (X1), pin 22 The BCM (Body Control Module) is the fuse/relay box on the front passenger side of the center console. Memory Seat 1 N/A Memory Seat 2 N/A -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
