Ok, so on friday I switched from using a .5 farad capacitor (which seemed pointless) to a direct 4 gauge to my amp (see sig for specifics) It worked fine until yesterday afternoon when I turned on the car and only the subs were working. All of the wiring to the head unit and the Alpine power pack thing looked fine, and the head unit seemed to be working fine besides not sending output to my door speakers. Then I left the car overnight to go camping, and when I got home just now I tried to start it and the battery was dead. I jumped it and I'm recharging the battery right now, but I have no idea what the problem could be. Help?
2002 Subaru Outback
Alpine CDM-9821
Alpine KTP-445
4 x Alpine Type R 6.5s
2 x Polk Audio MM 12's
Quantum Audio qsa1500D
How long has the system been in your car? Perhaps your alternator or battery is going bad, if you haven't added an extra battery.
POTATO!
Was your battery disconnected while working with the capacitor, or any live wires for that matter? :popcorn:
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
Do you think it could be your amp's rem switch inside not workin. Have you tryed other amps since then? This happened to me once
My First Build on SMD (Blow Through)
2004 Ford F-350 SD Lariat
Pioneer 3200BT DVD Deck
Infinity Reference Components not powered
Bully Dog Gauge Cluster Pyro, Turbo, Trans
SF3 SCT Tuner W/Customs
If you can't Join em' Crush em'
Also do you have inline fuses? if not and wires touched, coulda fried radio and everything
00' Nissan Xterra
That would be nasty had that happened slawsen. That wouldn't necessarily run the battery dead Unless some how it blew the battery. I could be wrong but its my thought
Did you unplug the RCAs and remote wire before messing with the cap wires? Did you double check the connection at the battery and the ground for the amp? Are you running an inline fuse? I have a feeling I know whats wrong, but I need more information before I can help you.
1989 Chevy Caprice Classic
350ci V8 High Performance
JVC Arsenal HU
JL XR series components
Infinity Reference 6x9s
Pioneer Premier 4-Channel
Clarion 2-Channel
Rockford Fosgate Series 1 2-Channel
Fusion 2000.1D
MTX Crossover
RF, Knu, Kicker, and Monster wiring
NVX VCW 12in. Sub **Won on here from the Sonic contest!**
*Build log coming soon!*
Starting all over pretty much which the gear listed...lost almost everything I had, including my life. Never take life and what's in it for granted.
Yes to all of those things. I generally know what I'm doing when it comes to car audio, but I'm completely stumped right now. I just went out and checked the battery and it's dropped down to 9.5v. It was at 12.5v last night when I got home around 11. I'm about to charge the battery, then pull out the fuse and see if it still drains power.
2002 Subaru Outback
Alpine CDM-9821
Alpine KTP-445
And the only thing what a capacitator in a caraudiosystem can do, is to strain your battery.
in this case, yes. but if you have no voltage drop, how is it a strain on the alternator?
  • Who's Online   0 Members, 0 Anonymous, 973 Guests (See full list)
