fiberglass box build in an 07 tacoma access cab
here is my truck and the first box as a reference
the old box was around 9.5ft^3 and tuned to around 35hz
plans are to build a fiberglass box that is a little bit larger and tuned lower and also place the port up higher but still have the subs firing up so that i can hopefully pull off some hair tricks. Im not sure yet what i want to tune it to but im thinking around 27-30hz. any input would be appreciated
pulled the old box out and the rear seats out
here are the materials from lowes, wal mart, and uscomposites.com
gonna use an exorbitant amount of mat and resin products to do a full enclosure. but why. do a majority of it in mdf and then you can make the face or what not from fiberglass. look at boilermakers truck.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
so after some more reading around i think i have decided to build a box that will be 10ft^3 after displacement and have three 6"x27" ports too equal 108in^2 of port area which is 10.8in^2/ft^3 and tuned to 27hz. also since the ports are so long i will have them firing up and the subs will still be firing up as well in the back of my ext cab truck
any suggestions on this design? the main thing i am hoping to achieve are some hair tricks
sub up port up... 27hz is too low in my oppinion... but thats cuz i got a wide range of music...
if its hair tricks your looking for... lower is better...whatever floats your boat... lol
My first truck... My first Real build...
*Update 8/9/10 DC Power 270xp Alt is In!!!*
1997 Toyota T-100 DC Level 5 18" in a T-line
Everybody wants their system to be....
1. Cheap
2. Reliable
3. Loud
...you can only pick two.
micahmye hertz pack
here are todays progress pics:
i removed the jack mount and jb welded the holes and taped up the area under the rear seats. hopefully i can build the frame with birch tomorrow and start glassing
  • Who's Online   1 Member, 0 Anonymous, 1425 Guests (See full list)
