Im running 1500cca's for 2 t-4's, neone no how many watts pushing to each speaker.
Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
ok which means,I gots a question for you by the way, what blows subs besides distortion.
one thing distortion is made from is clipping. which in turn means that you dont have enough power to the amp. so you send a dirty signal to the sub which is distortion. so what youre actually trying to ask, is if you have enough battery power?
So short on batteries will cause your subs to blow and the pole peice isnt moving fast enough and it melts.
The pole piece don't move. I too don't understand what your asking? You aren't running 1500cca to your subs are you? I'm lost.
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
unless you have tested what amperage you are getting to your amps via an "amp clamp" or simular metering device you cant just say Im getting *****amps to them. Amperage x voltage = true watts to your subs. And that will vary with what music or test tone you play while testing.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
