XS Power
I have a d2700 hooked up in my car, I just read the resting voltage with a Dmm... With everything hooked up to it and the car turned off it sits at 12.34... When the car is running the voltage reader doesn't really drop below 14.7, unless the bass hits, then it goes down to like 13.2 for brief periods of time...
That seems very low to me, am I wrong?
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
A fully charged battery should rest 12.6 or above, i believe.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
The battery is only about 6 months or 4k miles old, before I put it in the car I charged it fully like the warranty says to do.
Before I read the voltage I had the radio on for about 5 minutes without the engine running. I was not playing bass heavy music, just listening to some Christmas music in the garage.
I just went for a 20 minute drive, I'm going to let it sit for a few hours an then read it again.
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
also depends on how many miles are on the battery
how many miles on the battery huh?
u need to throw your battery on a smart or a trickle charge for a good ammount of time and condition it back to where it should be. 12.6-8
12.3 is low if that was the resting voltage. If you were playing music with the car off that would drop the voltage down. I would recommend fully charging the battery (should be 14.4V) and then letting the battery sit for 12-24 hours and checking the voltage again. If the battery in sitting in cold weather the voltage will drop lower than normal.
