my system contains the fallowing. a pioneer deck with 4v out puts and built in crossover for subs amp is a planet audio bb2 2400 running at 1ohm and subs are planet audio bb212d's box is tune to roughly 30hz subs are inverted. on my deck the cross over is set at 63hz and 50 on the amp. i like the feel it kinda bass. for the sub sonic filter it goes from 15hz to 40hz where should it be set at. right now i have it at 20hz
Team DBs (Driven By sound)
thats a little low it will still let anyhting 20 hz and up through. i like to have mine close to my tuning
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
using test tones and the subsonic filter OFF find where your enclosure unloads (when the subs are essentially just flapping in the enclosure because it won't pressurize the port) and tune the filter about 3-5hz above that.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
so bump it to 30 then? i just like the low low bass i rather feel it then hear it lol. o and this is in a 96 jeep grand cherokee
either tune the enclosure lower, or go sealed then
Principal
cant do another box til spring but by then i'll be doing 4 12's in a 25 hz box. just for now i just need a good sub sonic point til spring
are they unloading now?
Principal
if they're not unloading you don't need to change anything
Principal
