Just throw 2 dc lvl 2 8's in there :D
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Alright guys thanks for the help! How about this box? I haven't used an aeroport before, do they come like ready to go? What about the length? Does this level of subs need a double layer face? Or maybe just some 1" mdf?
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
I believe u can buy an aero port at a local stereo dealer and it's a basically cut and fit then glue type of thing as for the dcs maybe have ur 3/4 with a 1/4-1/2 in faceplate so they r counter sunk if you want to see aero ports look at Steves towers on YouTube and you can see them
1994 honda accord 2.2L VTEC
sub is re se motor with fi cone in a pre fab box
stock door speakers on an alpine v12 4 channel
sub on a 1000 watt alpine monoblock
need a dash kit and harness to put my alpine deck in
also need tons of sound deadner
need to install my apline type r compontents up front
need to buy type r 6x9's for the rear
Yeah I've seen them on there. And yeah I'll counter sink them. It'll probably look the best, especially since I'm flush mounting the amp!
Cadence FXA1600.2
Cadence S2W10
are you mounting it to the box?????
No, I haven't figured out where I wanna put it, but it'll be flush with whatever surface its against
Cadence FXA1600.2
Cadence S2W10
if you do plan on puting it on the box make sure you use rubber spacers other wise your going to jack up your amps internatls so remeber this when you get to that part
Id be more woried about braceing then thickness with only one 12. Cuz like you said your flush mounting it, itll prolly take 3/4in mdf to counter sink it all the way so that will be plenty!
Okay, so this box is gonna need some bracing on the inside? I didn't think it would being that it's only one 12" sub and a fairly small box.
Cadence FXA1600.2
Cadence S2W10
Depends on wut size wood and if u plan on fiberglassing the inside then you should be good look at meades build log and look at the boxes he's made most are very strong because of the fiberglass
