Alright, I've been workin on my mom to get some rumble in the trunk and she says she's interested, but it has to be functional. So here's my idea, I'm thinkin a box for one 12" that fills the gap from the rear seats up to the spare tire. Then she's still got most of the trunk for groceries/whatever and can still get to her spare. Dynamat might be on the to do list too. I'll post a pic of the trunk later.
I need some equipment suggestions though...
I was thinking that the stock head unit should stay in because it's kinda built into the dash. An aftermarket one that's not an expensive ass touchscreen would look stupid.
-3sixty processor
-12" P3
-P500
This stuff is a little pricey for her though, so if there's some better options/ideas, please share!
I also thought of using the tactile transducer. Is this a shitty idea?
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
I have an aftermarket stereo and theres a kit and makes it a double din with a little pocket for cd's or w/e
2011 Subaru WRX
Rockford Fosgate T1000-4AD
(2) Sets of Rockford Fosgate T3 6.5 Components
In the works:
Rockford Fosgate T2500-1bdcp
(2)DC Audio 12" XLM2
wow i usually frown upon camrys but this one looks clean and for the build i would go down a less expensive route by using LOC line out converter then just hook up an amp kit a nice mono block but the p3s are nice solid woofers all though u can probably get something better from audioque for the same price
honestly i wouldnt put in the 360.2 yet.. youd be way better off getting her new door speakers and rears with the 12 and get her a mids/highs amp also. save your money on the 360.2 for now.
Well yeah I know they got the kits but the radio kinda flows with the dash in the new Camry's.
Thanks man, I thought so too. I'll take a look at audioque too. So the LOC will allow me to control the sub separate from the speakers? Or just make a clean way to splice in the RCA's with the rear speakers? As I said to the guy at the bottom, I also just realized that I can run a bass knob.
I didn't plan on starting with the speakers just because the one's in there now sound pretty damn good as they are. And yeah those 3sixtys are pricey, I just didn't know of another way to get control over that sub without using the bass control from the radio...actually I could probably run a bass knob duh
Cadence FXA1600.2
Cadence S2W10
true that u can use this kit and make it look factory http://www.sonicelectronix.com/item_7736_Scosche-TA2058B-TA2058-Silver.html
Actually that doesn't look too bad!
Cadence FXA1600.2
Cadence S2W10
yeah on my moms g6 the speakers sound good till they get turned up then they just distort like crazy. id look and see if the h/u has rca outs on it.. if it does then you just saved alot of work and money. but i can almost promise your going to wana change the stocks out.
Yeah they'll go eventually but they already go to earpiercing volume with the bass all the way up playing heavy bass music without distorting. So with the sub in I'd probably cut the bass down to flat or a little higher and it would be plenty loud for her. I'll check for the RCA outs...I hope these new cars aren't a pain in the ass to get the stereo out...
Cadence FXA1600.2
Cadence S2W10
damn.. I guess this means you can't throw a box back there without hooking it up.
