2 18" DC lvl 5's 6KW of Sundown in a VW Lupo!
Ok guys I get that ill have voltage drop, and ill fix it once I find how bad it is.... why fix something I don't even know will be broken.
Thanks for the other "good" comments fellas.
Give us a TL vid if your voltage up.
"in the abundance of water, the fool is thirsty" Bob Marley
  • 5 weeks later...
Not updated for a while but got a fair bit done.
First bit of 18mm up.. will be double skinning it to 36 mm all round
Good days work today... got a fair bit done.
Trimmed all the foam and sanded the pu glue down from the join ready for the second sheets of mdf.
Started on the drivers side ... bottom piece was already in and foamed.
Nice thick bead of pu glue.
Top piece cut and held in with brakets until foam and glue sets.
Cut up the second piece of mdf for passenger side bottom. Little tip of jj. sand the shine off the mdf before adding pva. Cheers pal.
Covered in pva with roller.... another tip thanks to jj. and the proffessa.
Screwed in
Top part cut and glued and screwed.
Passengers side is solid now. The gap at the top will be fiberglass nice and thick to get some more volume.
Doubled up the drivers side and expanding foamed round the edges to seal it up nice.
4 of the 6v cells in and wired.
Big wheel well but still not big enough for all 6 batteries.
Battery tray expanding foamed in.
Snugg fit.
Cables all connected... thought it was a good idea to use butterfly nuts for ease of connection but I'm going to swap them for nuts because they just don't get tight enough for my liking, scared of them coming loose.
Backs on, also done some work on the centre partition and brace.
Cutout for the back.
Just about fitted two outta one sheet.
Double 18mil centre partition
Also built some runs for the cable.
Scuffed up where I was going to glass with the wire wheel.
Scuffed up the dynomat and paint off the car so it had something to cling to
4 layers of 450gm over the arch
2 layers on the joints
Decided Im changing the front end come end of feb to 4 sets of Hybrid Audio Imgine 6.5" components powered by two Sundown SAX 100.4 B)B). Wanted something that will sound nice daily driving but will keep up with the monsters in the back trying to blow my screen out :D
Managed to get 3 consecutive days off work next week so hoping to get a lot done
Stay tuned for more updates
nice build mate!
The Project!!
1954 Trunk Build
http://www.stevemeadedesigns.com/board/topic/102529-1954-chevy-belair-trunk-build/
The Daily!!
Head Unit: Alpine 9883
Subwoofer: 2 12's DC Level 4 XL
Amplifier: New DC 3.5 K
Rear Center Console: 1 8' DD 1508
Amplifier: Rockford fosgate 500
Mids and Tweets: Beyma tweets
e36 Trunk/Subwoofer Build
http://www.stevemeadedesigns.com/board/ind...showtopic=27903
It's the biggest I can fit on my car without custom brakets and alternators.... if u have problems ill change it, the car is only a 1.4tdi so adding stupid amounts of alts will lead to no power. Been told ill be fine with the power I have as there are no big alt suppliers in the UK.
mechman makes a 270 amp alt for audi and vw just thought id let you know
