Hey guys i need a box designed for a Fi audio X 12"
i have this much space to work with
43" width
16" tall
16" depth
It will be running of a Dual XPA6100 ( 300W will be going to the sub )
here are the sub specs
Fs: 25.7 Hz
Re: 3.9 Ohms/coil
Qms: 4.01
Qes: .38
Qts: .35
Mms: 120g
Cms: 3.2mm/N
Sd: 480cm^2
Vas: 104.1 l
Spl: 88.6dB 1W/1m
Bl: 20.0 N/A
Xmax: 16mm
Rms: 300W
Sealed box: .9-1.3 cuft
Ported box: 1.6-2.2 cuft
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 5.750”
Displacement: 0.10cuft
i would like for it to be loud ... lol :woot:
Vehicle: 1996 Chevy Prizm
Amplifiers: Dual Xpa6100(Sub)
Enclosure: BassWorks 2.5ish sealed
Mids/Highs: Polk 6.5"s and polk 4"s
Subwoofers: RockFord Fosgate 15"
Wire:8gauge
Future Upgrades:Amp, another 15" , Big #
i dont know weather to facepalm or not.....talk to saniterium? idk how to spell his damn name anymore i gave up awile ago, he does really sick designs, he did mine
sanitarium is his fourm name
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
i honestly don´t think you would be loud with that amplifier, i seriously hope you upgrade it later hommie, anyways, i would make the box 14"H x 30"W x 16"D , port 12.5"H x 2.5"W x 28"D giving you 2 cubic feet after displacement and 35 tuning with 14.5 SQ of port per cubic feet.
For such a small sub (strength and cone area) this is too big. I'm not at home right now so I can't get you a design, but you should shoot for 1.5 cubes after displacement, and keep the port relatively small too. Say 18 to 20 square inches of port total.
Ask onelivinglarge how having too much box for his fi x 15 effected him.
i advicing him that size because of the power he has, also, that port size because the xmax isn´t small at all, but once again, i haven´t used that sub before so if you say i´m wrong then i guess you are right, nice input then! :drinks:
i know i wont really be ... but i gotta make the best of it ... my dad went and bought it for me so ...
Wire:8gauge
thx btw... first *real* system ...
Edited by Ryeguy28
Wire:8gauge
so would a 26"W x 14"t x 14"D outside deminsions plus port of 2"W x 12"T x 28 work?
Wire:8gauge
no, your freq is way to high with that, your at 37.04hz and you need to be at 25.7hz. i got you at 26.52hz with a box that is h-14 w-40 d-15 with a port of 10x3x40
edit- i do want to say he did a good job with his question though. he gave all the info we needed. where usually it, i need one for my car, i have a 12in sub. gtfo. you know what i mean.... :drinks:
Edited by mprete
why does he need a 26 hz tuning? you tune your boxes at the same frequency as the FS of the sub???? 26 hz is LOW as hell if you ask me, he´s gonna be able to play only C&S music and lows, i wouldn´t tune lower than 35 hz, specially on a single sub setup, but that´s just me.
  • Who's Online   0 Members, 0 Anonymous, 2496 Guests (See full list)
