Im a little confused if this has to be done a specific way
Which one of these would work? or Both?
I was wondering if the remote wire has to be on the other remote wir terminal or you could make a connection....
OR you could use the pass-thrus as the remote?
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
What is the RF360.2 Used for anyway? isnt it a line driver i believe?
You can do it both ways like that. But once you have multiple amps you need to use a 12volt relay.
I thought it was only when running 3-4+ amps and a processor/line driver a relay was needed.
Op- I'm running my amps like the second picture and haven't had any problems
Edit. the 360.2 is a sound processor
Edited by mikeg321
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
I didnt need a relay when I was running 3 amps... And you won't need one if you are running the RF360.2, they're good for 1-5 amps...
OP, you should be fine...
Didnt know that about the 360. But I was talking more like my situation, where a have 7 rem wires for my amps ,and my POS maxxlink, that I need to unhook.
So basically The RF 360.2 is used to process the mid/highs amp and sub amp to hit the right freq?
Im just wondering how you would hook up the wires on this part of it?
thats for high level inputs. aka speaker wires from factory wiring.
If aftermarket source than you can certainly use RCAs instead.
Eclipse cd7000
So if you have an Aftermarket headunit you dont even have to use the highlevel inputs? or any of those inputs?
