speedball1978 Posted December 23, 2010 Report Posted December 23, 2010 box is already built into the trunk, i only have a 4.5 wide gap for a port, but i can make the height up to 14 i believe. What would be the recommended length of the port for 2 15's for per say 34 to 38 hz? This is where i'm kinda stuck... the box size should be around 8 to 8.5 cu ft when all the fiberglassing on the interior is done...
Sanitarium Posted December 23, 2010 Report Posted December 23, 2010 box is already built into the trunk, i only have a 4.5 wide gap for a port, but i can make the height up to 14 i believe. What would be the recommended length of the port for 2 15's for per say 34 to 38 hz? This is where i'm kinda stuck... the box size should be around 8 to 8.5 cu ft when all the fiberglassing on the interior is done... use torres calculator and frigure it out for yourself
SnowDrifter Posted December 23, 2010 Report Posted December 23, 2010 box is already built into the trunk, i only have a 4.5 wide gap for a port, but i can make the height up to 14 i believe. What would be the recommended length of the port for 2 15's for per say 34 to 38 hz? This is where i'm kinda stuck... the box size should be around 8 to 8.5 cu ft when all the fiberglassing on the interior is done... use torres calculator and frigure it out for yourself http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator-updated-310/#entry551556 ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
