Just bought a new WD 2TB Caviar Green internal HDD, it says its an advanced format drive and if Im running XP with multiple partitions I need their Align software, if I have XP with a single partition then I need a jumper. My current HDD has a partition for Windows but the new one wont have one (Just going to be for storage), so do I need the jumper or the software?
If I need the jumper, where do I place it? On top of the drive it says in the 7-8 spot but according to pics Ive found on google that seems to be the spot for it to be a master drive.
I pulled a jumper off of my old IDE Seagate hdd, will that cause any problems if I use it on this Sata WD?
EDIT: Got it figured out
Edited by Velvetdreams21
1993 Cadillac Fleetwood Brougham.
Jensen UV10 DVD HU
Two 12" Sony Xplode (temporary)
first of all i take it that this drive is SATA. If so, you do not need to use the jumpers since there is no master/slave options, they are all cable select, or in other words set in the BIOS.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
