S15_Silvia Posted December 26, 2010 Report Posted December 26, 2010 Hello all. I'm running a QSC RMX 850 amp on my 12" sub (seen in sig). It's bangin' for parties and whatnot at home. Anyway, I decided to take my DMM to the amp today, and see what it's really putting out. It's rated for 830W RMS at 4ohms bridged. The sub it built for 1000 RMS, so it should have no trouble taking this amp. However, my tests worried me just a little. I took the DMM, on AC volts, and played a 40hz sine wave (no speaker connected) with the gain at 26/30. Now, I never play the sub with the gain this high- it was more for shits and giggles. I got 78.1v. At a 4 ohm load, using P = V^2/R, that gives me about 1500W. How can that be? If that IS the case, this is one hugely underrated amp... 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
iceman1575 Posted December 28, 2010 Report Posted December 28, 2010 Hello all. I'm running a QSC RMX 850 amp on my 12" sub (seen in sig). It's bangin' for parties and whatnot at home. Anyway, I decided to take my DMM to the amp today, and see what it's really putting out. It's rated for 830W RMS at 4ohms bridged. The sub it built for 1000 RMS, so it should have no trouble taking this amp. However, my tests worried me just a little. I took the DMM, on AC volts, and played a 40hz sine wave (no speaker connected) with the gain at 26/30. Now, I never play the sub with the gain this high- it was more for shits and giggles. I got 78.1v. At a 4 ohm load, using P = V^2/R, that gives me about 1500W. How can that be? If that IS the case, this is one hugely underrated amp... Wouldn't surprise me QSC have some great amps. Are you sure the sub is wired at 4 ohms? I'm assuming the sub is either a dual 2 ohm or single 4 ohm? POTATO!
S15_Silvia Posted December 28, 2010 Author Report Posted December 28, 2010 Yep, it's a dual 2, coils in series. I guess I'll just have to be careful with the gain...maybe see exactly where 1000W is 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
Boon Posted December 28, 2010 Report Posted December 28, 2010 It's because your DMM is reading peak, not true RMS. And it's probably clipping to hell which will falsely inflate the voltage read by a cheap DMM. Put a scope on it and it would be a very different story. To get the real number, divide by 1.414 = 55.223vac = ~762wrms @ 4 ohms. 10.x volts fo' life!
Guest Posted December 28, 2010 Report Posted December 28, 2010 It's because your DMM is reading peak, not true RMS. And it's probably clipping to hell which will falsely inflate the voltage read by a cheap DMM. Put a scope on it and it would be a very different story. To get the real number, divide by 1.414 = 55.223vac = ~762wrms @ 4 ohms. the man himself. let me ask you this, what does the 1.414 correlate to?
Boon Posted December 28, 2010 Report Posted December 28, 2010 It's because your DMM is reading peak, not true RMS. And it's probably clipping to hell which will falsely inflate the voltage read by a cheap DMM. Put a scope on it and it would be a very different story. To get the real number, divide by 1.414 = 55.223vac = ~762wrms @ 4 ohms. the man himself. let me ask you this, what does the 1.414 correlate to? The square root of 2, which is the ratio between peak and RMS It actually goes forever, like Pi. EDIT: P.S. What's up Kranny... hope you had a good christmas, man I haven't been on here in a while! 10.x volts fo' life!
S15_Silvia Posted December 29, 2010 Author Report Posted December 29, 2010 It's because your DMM is reading peak, not true RMS. And it's probably clipping to hell which will falsely inflate the voltage read by a cheap DMM. Put a scope on it and it would be a very different story. To get the real number, divide by 1.414 = 55.223vac = ~762wrms @ 4 ohms. Now that is knowledge. I like it. I would like access to an oscope to be honest- fortunately, I don't really run the amp above half gain. The 26/30 test was basically for the lulz, but yeah, as soon as I find someone with a scope (or buy one perhaps) I'll see what's really up. However, there's no doubt in my mind that this is a great amp. 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
S15_Silvia Posted January 2, 2011 Author Report Posted January 2, 2011 Quick question for you guys- I have access to a Snap-On Modis scanner, you know, the like $5000 diagnostic tool. It says it has a scope function, but would it be capable of dealing with the power put out by this amp? 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
Sanitarium Posted January 2, 2011 Report Posted January 2, 2011 1. check voltage output of the amp with the speakers connected. gurantee it can't do as well with a load. B. no matter what you do, your sub will not stay 4 ohms during use. It will go up. Third. Any oscope has a HIGH resistance across it's probes. Meaning the oscope's circuitry will only see a VERY small amount of power from it's input.
