I have a 97 Honda accord, it has a sohc f22 non vtec engine in it, and it's an auto. but recently it blew a head gasket, and now the tranny is acting up.. I was wondering a about maybe putting a newer k24 in in and a 6 speed, or maybe a h22 from a prelude. Any ideas? I've also heard the h series engines bolt up to the f series engines with no problem, so maybe a h22 and automatic?
it's a 97 accord why not just buy a prelude instead of a motor/tranny swap?
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
just go with a f23a1 from a 99 accord ex its vtec and about 150hp it should drop right in and you would just need the switch out you ecu unless your aiming for big hp numbers
"Gettin dirty looks from those other Ricey crews"
i'd just go with the f23a1, its a motor designed for the car (mounts and such) if you want a little more then go with a b series.. but if you have the money, time and skill, then go for the k24/k20. f series motors are out of my league though lol i only specialize in d and b series as of right now. haha but if you need any help with anything theres a few of us honda guys on this forum that know their stuff.
apparently you dont get the fact that the subaru was wrapped around a pole. and by the status of your comment, im guessing your mouth is too.
Vehicle: 1997 Honda Civic EX
Exterior: 55w 5k Headlights and 35w 3k JDM Fogs. Lowered. Sittin on steelies right now
Amplifiers: Rockford Fosgate P450.4
Batteries: Kinetik HC 800
Electrical: Big 3 in 1/0
Enclosure: n/a : (
Headunit: Clarion VZ409
Mids/Highs: Pheonix Gold Rsd6.5's in the Front Doors
Subwoofers: n/a : (
Wire: Knukoncepts 1/0 and 4g
Future Upgrades: 20% tint all around, GC/Koni coilovers, body work (fml) lol
Thanks for the suggestions, the only reason I'm going for the k swap is because it's a brand new engine. The k24 that I can swap makes only 160 hp, but I could easily make 200 with minor modifications. And I'm sure a k24 with around 40,000 miles runs way better then a semi blown sohc f22 with 300,000+
but your going to be paying out the ass for it lol why not just buy a d series motor and boost it, i have a d16y8 and i just bought a 20g turbo yesterday. so when its all said and done i should be making around 210 on the stock motor and 8-10 psi, and in the spring i'll be building the bottom end and have roughly 300 whp on low boost. while still getting 30 mpg : )
Enclosure: n/a : (
Subwoofers: n/a : (
K24 from a newer accord would not be expensive. You should look into that if you want the K.
There should be a shit-ton of info on the web that will help you out.
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
