1997 Accord Build lawdy lawdy
I feel bad for ya bruh... Parents got the leash tight round your neck if you have to ask permission to do all this shit :D
Team MaxRetribution
Si Vis Pacem Parabellum
no shit man.. But hit me up on places to put amps. im curious now
2006 Nissan Z Track.
My Feedback Thread
Change of plans guys. 18 wont fit due to height restriction of the brackets that hold the trunk up. I decided to go bigger than an 1 18 (cone area wise) so im doing 4 10's. The goal? To move a ton of air. Where the fawk do I buy 8" precision ports?... Or PVC? Anyone know any good retailers?
My Feedback Thread
And smoked, Amp places pleasee :)
&& Also, this box 'should' slide in since its only 13 inches tall. Well find out once the wood gets cut, and I test fit it in there.
and dont worry, the top will have some 1/2 threaded rod going in 2 spots in the middle of all 4 subs. It will also be all fiberglassed inside. Outside of box will be resined, (edges specifically) then be finished like my tweeters, that nice glossy black.
My Feedback Thread
MDF (Medium Density Fiberboard) is intended for interior, non-structural projects like counter tops, etc. MDF Super Lite is 1/3 lighter than regular MDF. Maintains excellent strength, surface smoothness and stability.
use MDF super lite.... works the same and is hella light i built 4.5 cube box for 15 i can load and unload by myself like nothing haha 40$ a sheet though :(
R.I.P!
(Nov-29-2009)
92 explorer
current build
dont think home depot has that. The box will be made of birch.
My Feedback Thread
got some work done today. mainly cleaning and other stuff.
cardboard layin around, thought I'd measure how the new box will fit. It will slide in :) No building in the trunk.
got this little piece back in, and stock speaker grills.
wires..
finally cleaned ready for damplifier.
My Feedback Thread
To come:
false floor
damplifier
new wiring
My Feedback Thread
What kind/brand of damplifier are you using? I ask because I want to put that stuff in my car also. Looks good, interesting route you just went to, i will be curious to see how this is all going to work out. What kind of 10's are you thinking about using? DC I'm assuming...? If so what level of 10's?
second skin in the trunk, and im going to beef up the lid and rear deck more since firing up will beat the hell out of the upper part of the car. And I already called anna and got a quote for 4 lvl 2 10's. I'll run something around 1500w to em.
My Feedback Thread
