94 explorer 2 RE Audio MX 18
Honestly 2000rms is where I'd be with them
yeah.i know im getting the aq3500 for sure. not two of them tho
  • 1 month later...
did some work this last week. put an exhaust on the explorer as well as a billet grille and decals. I ordered a mechman 270 amp alternator, an aq3500, and a couple of batteries from poundstone. and also took my backseats out to make room for a amp rack and battery box
  • 4 months later...
time for a rebuild doing sub up port back with 3 6" aeros putting my alt and sound deadener in.
best score so far
What are the new box measures? is you are building it in the trunk i guess it´s gonna be kind of tall, ports might choke a little bit IMO
a 47 is pretty bad for the equipment involved, my SX in my explorer were alot louder then that. off 2krms.
kinda sucks that its only like 42 across, all back would have been loud. but subs up and port back work great in that truck.
Yes it does, i always try to keep my mouth shut because everybody seems to be offended by every comment or input we give, but 2 smaller subs can get WAY louder on a proper box, i don´t understand why people try using 2 18´s in a small trunk facing everything up instead of going with only 2 15´s instead with subs up/port back wich is way louder on the explorer, the explorer SUCK ass with everything facing the roof, i would try a way more efficient box with subs up/port back but i don´t think you can fit it in the trunk with back seats on.
im doing sub up port back with 3 6" aeros on the new box. the dimensions are 18hx41.5wx32.5d double baffled. the old box we just threw it together it was my first box. as far as the score goes my voltage dropped to like 11 volts with the aq3500 so im upgrading electrical and better numbers to come
also my back seats are taken out for more room and the previous box we tried to keep under the window line and behind the seats
Hey hommie, one question, if you ditched the back seat, why are you going with such a small port area? you have a lot of room now for a good box, i wouldn´t use anything smaller than 4 6´s on those subs, that would give you around 35 hz and very close to the internal space you have using 3 6" , that would give you mroe output, just my opinion, good luck with the new build, i´ll be tuned in for sure!
