well lets say i have a 270 high out alt, d1200 in the hood and 2 d3400 in the trunk (xs power) is it possible to have my voltage below 15volts? and stable there? because of what i hear if you go above it then we will have to change to a differnt voltage of battery insteand of the 12-14volt battery
i dont know if what im typing makes sense
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Most vehicles will be fine at 15V... What is your voltage at now? MLA's and VCMs can regulate voltage coming out of your alt...
well right now i dont know its stock sorry, but i just about to click on a dc power and order the xs power batteries as we speak but before i spend more then a grand it will smart to double check sorry if this doesnt help with the question, and it says it has a internal voltage regulator just didnt know if that's all is needed to be fine
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
What kinda amp/amps you running? It all depends on the load.
as of now aq3500d.1 bass and RF Power T600.4 or T400.4 might sell the 600 for an 800.4 no sure tho
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Well hmm lets do the math on this.
270a alt minus what the car needs to run (roughly 40a maybe more) and minus the 380a of fusing on the AQ leaves 150a of current draw split between 3 batteries means each battery will have 50a of draw at full tilt at max alt output.
So you will see your voltage doing down, but as long as your smart you'll be fine.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
that isnt what i meant about the money issue, i was worried about buying the wrong type of batteries and wasting my money that way, and this is just my daily driver i use want stable voltage to run my equipment efficient nothing more, dont want crazy voltage drop and damage my equipment
sorry if that's how i came across
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Then opt for more alternators. That is the first place the amps pull current from.
Tercel build R.I.P.
V-Dub
My feedback.
will it drop enough to damage me equipment tho? also you think if i buy bigger batteries in the trunk will that help? and perhaps a battery charger and charge them at night? or maybe buying a better alt?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
also can you tell me the math you did on figureing it all out? so next time i dont have ask people this question again wanna learn something today :)
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
  • Who's Online   0 Members, 0 Anonymous, 3082 Guests (See full list)
