First Time Fiberglassing Dorr Pannels ( Pics+ Advice Needed)
kbreudi
Some pics from today
Posted Image
Posted Image
Posted Image
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
SSMB6 cant handle under 150 htz. my ssmb8 r at 120 and i had to lower the gain a little. if u want max output without the midbass bottoming out set hp to around 150.
But that dont make sence ill have this huge open freq. range from 80 to 120 Hz?????
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
No u wont...because x-overs dont completely cancel out a certain freq., the kicker 3 way has a 12db slope which means after a certain freq its set at it reduces 12db per octive. so your subs will still play higher notes just not very prominent. the ssmb6 will play lower than 150...just not very prominent either. no worries it should all blend.
Oo i see so thats what a slope is. So does it go something like this...hi passed at 150 Hz, every 8 Hz lower that 150Hz is will reduce the signal by 12 Db? How audible is 12 Db less? WWere abouts will the sub take over from the bidbass?
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
at 80htz lp for the sub it will probably still have audible sound up to 100-110htz and the ssmb6 will be audible down to about 100 htz, but they wont bottom out because that freq will be down alot of db.
  • 3 weeks later...
Well finnaly decided to finish em up and use spray on deb liner instead of the vinyl.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
The driver side is trying ill have pics of them installed tomarow. I think for my first fiberglass project it went well. Learned a hell-a lot too. Now i wanna start glassing everything in my car!
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
They look nice :)
Im not sure if Im liking the speaker grills tho.
LOL yea there the ones that came with the kicker compoent sets..they look nikda plain with no grills tho. Are all 5 1/4 and 6 1/2 grills the same size? Maybe i can get a different set?
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
So they are all sharing air?
I woulda sectioned off the midwoofer by itself.
Hopefully it sounds good.
Looks good.
GREAT job for a 1st try.
U should be proud.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Looks good.
U should be proud.
See i had some people say to create a seperate champer for the midbass, and leave the two midranges togeather. Maybe ill see how it sounds and then try it that way. Thanks for the compliment :D
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
