i have mine at the back battery, was reading werid every time it was at the amp, i even had a dmm on the same spot, stinger meters are beat
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
stinger meters are known to get vibrated outta spec but you can adjust them..
i always read directly from the amp inputs.. that way you see exactly what your amp is getting.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
Is there a way to have it switched on and off with your car? Or does it just not draw that much to have to worry about it staying on overnight.
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
i would assume you could hook it up to a switch.
just hook up a relay to trigger off your ignition and then run the power in off your amp and then the power out to the meter..
Edited by chewie
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
just got am email saying they will be here at the end of the month :(
damn international shipping.
get pyle on the inside of your butt cheeks...so every day you can take a pyle of shit
I got one of these for the same price like 2 months ago ... Works great ... Doesn't have a remote tho so it stays on even If the car is off :/ ... .. I'm thinking of buying like a toggle switch to it so I can turn it off ...
  • Who's Online   0 Members, 0 Anonymous, 2212 Guests (See full list)
