pioneer9412 Posted January 8, 2011 Report Posted January 8, 2011 Is there really that much of a difference in sound quaility between 2 volt and 4 volt preamp outputs?
Ford302Redneck Posted January 8, 2011 Report Posted January 8, 2011 I've seen a lot of post lately about preout voltage. We need a sticky.
Beanz Posted January 8, 2011 Report Posted January 8, 2011 yes.....that way you dont have to turn up the gain as much on a 4v then a 2v. and gives it a cleaner signal That's why they don't deliver. Yer ass better go sit along the side of the road and wait. You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
Rebel4055 Posted January 8, 2011 Report Posted January 8, 2011 Higher preout means less "dirt" in the signal Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
Ford302Redneck Posted January 8, 2011 Report Posted January 8, 2011 Omg. Wrong and wrong. Please don't answer if your not 100% on a answer. Just cause you have to turn up the amp more with 2 volts than you would with 4 volts, don't mean its going to clip. Preout voltage is for gain matching that's it.
Rebel4055 Posted January 8, 2011 Report Posted January 8, 2011 I hope your not saying I'm wrong Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
Ford302Redneck Posted January 8, 2011 Report Posted January 8, 2011 There isn't any "dirt" flowing through the RCA's...
Rebel4055 Posted January 8, 2011 Report Posted January 8, 2011 There isn't any "dirt" flowing through the RCA's... Do you have any idea what I meant by dirt? "The higher pre-out system should have less chance of picking up noise." Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
uhoh_45 Posted January 8, 2011 Report Posted January 8, 2011 Omg. Wrong and wrong. Please don't answer if your not 100% on a answer. Just cause you have to turn up the amp more with 2 volts than you would with 4 volts, don't mean its going to clip. Preout voltage is for gain matching that's it. preout voltage from your deck has to do with gain matching how?? (explain gain matching) R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Ford302Redneck Posted January 8, 2011 Report Posted January 8, 2011 What's the gain knob for? To match the output voltage coming from your headunit. And how does less volts pick up noise?
