yes.....that way you dont have to turn up the gain as much on a 4v then a 2v. and gives it a cleaner signal
There isn't any "dirt" flowing through the RCA's...
Do you have any idea what I meant by dirt?
"The higher pre-out system should have less chance of picking up noise."
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
Omg. Wrong and wrong.
Please don't answer if your not 100% on a answer.
Just cause you have to turn up the amp more with 2 volts than you would with 4 volts, don't mean its going to clip. Preout voltage is for gain matching that's it.
preout voltage from your deck has to do with gain matching how??
(explain gain matching)
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 405 Guests (See full list)
