depends on your setup. with a processor it means you are going active. toss out the passive crossover and get each speaker on its own channel.
remember an EQ is to help with SQ. not to just boost, boost, boost. its doing the exact same thing as the "bass boost" on the amp so be smart about it.
"front" "rear" and "sub" outputs on the EQS are independent.
Edited by skittlesRgood
i might be opening a can of worms but is there a benifit to going active or passive
2007 mustang
Boyo avn701d
hifonics bxi2610
2 olm 2415s
hifonics 100.4
2 infinity 6x8s
2 kicker comp cvt 8s
hell yes there is a benefit going active. the only 2 up sides to passive is that it takes half the channels and you dont need to know shit about crossover points. its just simple.
going active will yield better SQ, higher volumes (because the passive xover takes up a lot of power) and MUCH more customization.
so im going to have 8 speakers on 4 2 channel amps then 2 sub amps, so what would i need between my hu and my amps to make them active?
sorry i know a lot of questions, ill admit im a noob!!!
2007 mustang
Boyo avn701d
hifonics bxi2610
2 olm 2415s
hifonics 100.4
2 infinity 6x8s
2 tweets per channel
2 mids per channel
R.I.P!
(Nov-29-2009)
92 explorer
current build
sorry i meant 2 4 channel amps
and what do i need to install between my head unit and my amps to make it an active set up?
Edited by bigkevy
2007 mustang
Boyo avn701d
hifonics bxi2610
2 olm 2415s
hifonics 100.4
2 infinity 6x8s
could be as simple as a crossover or as complex as a processor.
list the types and locations of the speakers.
i was thinking of going all rf power series. id have the t1692 in the bottom of the door and then 2 or 3 1652s towards the top of the door. this would be on both sides obviously and then probably 2 1652s on each side in the back seat area, so id probably end up doin 3 t400.4s its all going in a mustang, kinda goin for the WOW factor
2007 mustang
Boyo avn701d
hifonics bxi2610
2 olm 2415s
hifonics 100.4
2 infinity 6x8s
