39 years? wtf?
Hey Iam hella suprised MTX factory out let is seeling those things for the same original price og $999.... plus that voice coil is so short, dunno if I would believe it is a 4" xmax capable sub, unless its a dual gap motor design
It sounds like you built the box first and then tried to calculate and add a port. You're supposed to figure out your port first and then adjust the box size accordingly for displacement. You said the box size was 8.7ft but when you add the port that will change because of port displacement. The added displacement will then change the tuning. Good Luck with this build. I hope it still works out for ya. You should post all your info here such as box height, width, depth, thickness of wood used, double baffle?, and port height, width, and depth. Then let us figure what its really tuned to.
  • Who's Online   0 Members, 0 Anonymous, 1561 Guests (See full list)
