what terminals would you need to run 3-5 runs from the front to back batt? lol.. ive seen 2.. not 5
I can make you some.
PM Sent ..
1998 GMC Jimmy 4 Dr.
-SINGER 275 Amp Alternator
-150 FT. Of 1/0 OFC (8 runs) 4 pos, 4 neg. Front-back.
-Audioque AQ2200D @ .5 ohm
-2 Audioque HDC3 18's Tuned to 27-29 HZ
-4 Clarion 6.5's
-2 Optima yellowtops
Copper vs low grade steel. Copper will ALLWAYS win. Unless you drive a aston martin with aloy frame :D
But if it's grounded in front then it's grounded in the back right? So why do you want long grounds? I thought you want grounds short as possible?
If your not running a batt in the front then what makes the front ground better than the back?
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
A lil lesson on how the alternator works its going to be brief. to complete a circuit you have to have power and ground. the back half casing on a alternator is the ground the terminal bolt is positive.power has to flow through the alt mounting bracket through the engine block through the factory ground strap to the frame. maybe a lil bit through engine mounts and tranny mounts but they are rubber or plastic. thats why the big 3 works you upgrading your factory ground. Imo its best to go from alternator mounting bolts to neg on battery then to the back with 0g. copper is a way better conductor than steel (your frame). like i said earlier its the flow of least resistance.
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
so no matter what you run.. you need to have equal runs of positive and ground?
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
thats what i would do. but! if you cant afford neg runs you can use the frame as wire. :) same amount of negs as pos
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
does it matter how long the runs are if you ground to the frame?
in the front i went from back of alt straight down to frame 18" total 3 runs of 0g on each side of motor. then in back i went from my batterys through the floor to frame maybe 2ft. 6 runs also i have steady voltage for pulling 800+ amps
Edited by dc98hoe
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
so your grounded with runs from the front to back and in the back your grounded to the frame?
Realistically if the grounds in the back are short and you're using the frame as ground you don't need anywhere near as many grounds off the rear battery.
If your amps are grounded directly to the batteries in the back then you only need grounding capacity equal to your alternator output. At ~1ft long, you could use a single piece of 0ga for ~500A all day with no issues. Probably more.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 2212 Guests (See full list)
