bass_stalker Posted January 13, 2011 Report Posted January 13, 2011 what is trimode operation on an amp? JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
MrSkippyJ Posted January 13, 2011 Report Posted January 13, 2011 what is trimode operation on an amp? not worth worrying about. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Boon Posted January 14, 2011 Report Posted January 14, 2011 what is trimode operation on an amp? not worth worrying about. +1 Waste of time really. NFI why they include it in amp wiring diagrams. Was like 80's style perhaps. 10.x volts fo' life!
bass_stalker Posted January 14, 2011 Author Report Posted January 14, 2011 what is trimode operation on an amp? not worth worrying about. +1 Waste of time really. NFI why they include it in amp wiring diagrams. Was like 80's style perhaps. thanks for the info JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
CaptainzPlanetz Posted January 14, 2011 Report Posted January 14, 2011 My PPI A404.2 has that option listed in the manual, Here is a paragraph or two out of the manual, so basically you can run 4 stereo channels as well as 2 briged mono channel's??? IDK its confusing Im just using it for components so..... All ArtSeries amplifier are capable of being bridged into a mono output due to the internal design of the amplifier. This feature permits the creation of a mono channel for a subwoofer or center channel. Also bridging adds flexibility of operation. Any of the ArtSeries two-channel amplifiers may be used in a one channel (mono), two channels stereo, or 3 channels - 2 channels stereo and one channel derived mono configuration. ArtSeries four-channel amplifiers may be used as 2 mono channels, 3 channels - 2 channels stereo and one bridged mono channel, 4 channels - 2 channel (stereo) front and rear, 5 channels - 4 channels stereo and one derived mono channel, or 6 channels - 4 channels stereo and 2 derived mono channels. Deriving the mono channel is accomplished by using the left channel positive wire as the positive speaker wire and the right channel negative wire as the It is important that a minimum of 4 Ohm impedance is negative speaker wire. observed. If the impedance drops below 4 ohms while the amplifier is wired in the mono configuration protection circuit will engage the output power will be AM II mono configuration, the reduced. The ability to run stereo satellites wile simultaneously running a mono output from the same output stage is accomplished simply by running the stereo speakers normally and tappng into the appropriate wires for teh "Mixed Mono" channel (left channel positive wire as the positive speaker wire and the right channel negative wire as Again, for optimum performance, speaker impedanc Some of that doesnt quite copy right, so here is the link, its on page 9 under bridging http://www.precisionpower.com/Manuals/Amplifier%20Manuals/Precision_Power_Art%20Series%20Axxx.2%20Amplifiers.pdf ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
