4 z V.3 18s 18v and a big 4th order
THAT'S IT IM DOING MY DOORS!!
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
thanks man im happy how they have turned out so far
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
its very intimidating but all in all its not that hard just take your time and plan and when you get to the point of actually mixing resin know you have 15min or less to work so get everything layed out the way you want it then mix resin very last
i told you sucka let me know when you want to sand on mine.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Mix and work in the shade.. You should have 30min of work time. Or your mixing to hot.
i was just going by what the label on the resin said i know depending on what the mixture is will give you more or less work time but i figured 15min was a mean im about to go back out and start the second panel and im going to mix with a little less mekp cause last time it started to goop on my towards the end
