Vazzil Posted January 16, 2011 Report Posted January 16, 2011 What's a good amplifier to get with these kickers on amazon http://www.amazon.com/gp/product/B000XPV7PO/ref=ord_cart_shr Would the Hifonics HFi1500 Hfi Series D-Class Mono Amplifier 1 x 500 @ 4 OHMS, 1 x 1000 @ 2 OHMS, 1 x 1500 @ 1 OHM be any good? http://www.amazon.com/gp/product/B0036B8UPW/ref=ord_cart_shr?ie=UTF8&m=A3MJ987JELUZUB
hdorre Posted January 16, 2011 Report Posted January 16, 2011 Nope. Even on an amp that didn't do 700watts, the setup should suck ass. The box is prolly tuned insanely high. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Vazzil Posted January 16, 2011 Author Report Posted January 16, 2011 Nope. Even on an amp that didn't do 700watts, the setup should suck ass. The box is prolly tuned insanely high. Do you know a good amp I can find on Amazon that would be great for the kickers?
Guest Posted January 16, 2011 Report Posted January 16, 2011 unless you want to power your subwoofers to like 1/4 their handling potential, then go ahead and get the Hfi line of amps. its pretty strange, over the last few weeks we have had MANY MANY members ask constantly about the Hfi series. its really weird haha. but anyways here is an amp that can work. http://www.sonicelectronix.com/item_23548_Hifonics-Brutus-BRZ1200.1D.html if you got the Dual 4 ohm version of that setup then you would have cheaper versions, because wiring at 2 ohms requires a larger amp because of the resistance load. having 2 Dual 4 woofers lets you wire at 1 ohm and lets you use the full potential of amps that are 1 ohm stable.
Vazzil Posted January 16, 2011 Author Report Posted January 16, 2011 unless you want to power your subwoofers to like 1/4 their handling potential, then go ahead and get the Hfi line of amps. its pretty strange, over the last few weeks we have had MANY MANY members ask constantly about the Hfi series. its really weird haha. but anyways here is an amp that can work. http://www.sonicelectronix.com/item_23548_Hifonics-Brutus-BRZ1200.1D.html if you got the Dual 4 ohm version of that setup then you would have cheaper versions, because wiring at 2 ohms requires a larger amp because of the resistance load. having 2 Dual 4 woofers lets you wire at 1 ohm and lets you use the full potential of amps that are 1 ohm stable. Is there anything on amazon thats close to that?
Guest Posted January 16, 2011 Report Posted January 16, 2011 http://www.amazon.com/Hifonics-Brz1200-1d-Certified-Monoblock-Efficiency/dp/B003SW3RCK/ref=sr_1_1?ie=UTF8&s=automotive&qid=1295209581&sr=8-1 really not that hard dude....took my literally a few button clicks and a single copy paste. edit: also if you didnt get the subwoofers yet, find one that is dual 4 ohm, or a 1 ohm final load. this will help you save a little money with an amp
DBz Posted January 16, 2011 Report Posted January 16, 2011 unless you want to power your subwoofers to like 1/4 their handling potential, then go ahead and get the Hfi line of amps. its pretty strange, over the last few weeks we have had MANY MANY members ask constantly about the Hfi series. its really weird haha. but anyways here is an amp that can work. http://www.sonicelectronix.com/item_23548_Hifonics-Brutus-BRZ1200.1D.html if you got the Dual 4 ohm version of that setup then you would have cheaper versions, because wiring at 2 ohms requires a larger amp because of the resistance load. having 2 Dual 4 woofers lets you wire at 1 ohm and lets you use the full potential of amps that are 1 ohm stable. Is there anything on amazon thats close to that? Get those subs, like he said, as the dual 4 ohm, that way you can wire down to one ohm. (2) Kicker L5 12's Alpine IDA-X305 HU Dual Optimas Big three Kenwood EQ RF Components Hifonics Brutus 1K (Subs) Alpine MRP 250 (Mids/Highs) Lots o' sound deadening
baaudio Posted January 16, 2011 Report Posted January 16, 2011 i would do a 750-800 watt amp Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
bumonskateboard6 Posted January 16, 2011 Report Posted January 16, 2011 Amazon has that same amp for sale...however is there any particular reason you want those subs in that crummy box? You could save money and buy the subs and build a better box...just my 2c though Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
