2 JL 10w7's w/ JL 1000/1, need some help!
@ zayres29- No reason, just thought it would be better just to upgrade the batt, plus I thought it would be more of a pain to run a 2nd batt to the rear. Dont want to do it if I dont have to...? Suggestions?
Right now, they are each in the stock Pro wedge box. I havent installed them yet, I plan on having them mounted in a dual ported box built to JL spec.
Side note: should they face to the rear of the car or subs facing toward the front?
don't do it to jl's specs, I was just wondering because I got a design and was wondering how w7's would sound in it
??? So then what do you suggest? Keep in mind I dont have much room in the trunk. about 38" wide by 18" height by 18" deep. The dual ported box would actually fit perfectly.
The dimensions are greater but for a standard rectangular style box thats al i get!!!
yes if i was you i would keep the stock batt and have the kinetik in the trunk its not a pain to wire at all just run a pos and neg from each terminal on each batt
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
ah my box is 33 wide, 14 tall, 21 deep subs/port back. it's a rear loaded horn variation. the jl boxes don't sound that great come out peaky and not enough port
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Well if the height of the box was brought down to 14", I'll have to remeasure to see if I have the depth for 21". I've got infinity kappa perfect's dropped in from the top, thats what was limiting my height/depth...
alright you decide you want it let me know and I'll send you the design/cuts just make sure to give me a review on it
I have 2 of the jl 1000/1v2 amps and I used to have one with a hc 1200 and stock alt. You should b good with what u have. The lowest I dropped with one was probly like 12-13. But use both batts
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
I also did the big 3 and got a smaller pulley for my stock alt. It does make a difference
Build Log
2 questions-
Do i use the stock (no name) battery running to the HC1200?
Should I run a battery isolator between the two batts???
Thanks!!!
The way mine was setup was I had the stock a run of 0 to the second batt in the back by the amp then the 4 gauge coming out to the amp
Build Log
  • Who's Online   0 Members, 0 Anonymous, 4768 Guests (See full list)
