cgrez33 Posted April 26, 2011 Report Posted April 26, 2011 How does one determine the pressure points in an enclosure? The ones that should have 45's? Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
fecupe2001 Posted April 26, 2011 Author Report Posted April 26, 2011 How does one determine the pressure points in an enclosure? The ones that should have 45's? Great question, after this testings i learned that, at least on a regular ported box, the pressure points are the ones where you need to help the air be pushed to the port??? i dunno for sure just yet, but taking as an example a subs back/port back application (same thing that sub up/port up and sub forward/port forward if you see the box from another angle), i would get just 2 vertical 45´s on the back corners; on a sub up/port back i would get only the 45 on the horizontal back corner, someone correct me if i´m wrong... PS: Every application is different, i´ve seen people gaining A LOT by doing 45´s on every corner of a wall!! I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
cgrez33 Posted April 26, 2011 Report Posted April 26, 2011 Ah ok, I understand it now. Yeah the concept was clear lol. Gracias por la informacion tan basica pero bien importante y no tan conocida! Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
fecupe2001 Posted April 26, 2011 Author Report Posted April 26, 2011 that´s using google translator??? that´s a very good spanish lol By the way, on a burp application subs forward/port back, i wouldn´t try any 45´s at all... I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
cgrez33 Posted April 26, 2011 Report Posted April 26, 2011 Lol No I'm mexican and chilean. Born and raised in the U.S Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
fecupe2001 Posted April 26, 2011 Author Report Posted April 26, 2011 Tequila y vino carajo! jejeje I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
cgrez33 Posted April 26, 2011 Report Posted April 26, 2011 Haha solo lo bueno. @topic in most applications for a trunk build would it be recommended to fire forward completely sealed off from the trunk? In the same scenario would it be recommended to put 45's in the two back corners? Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
BassJunkie Posted April 26, 2011 Report Posted April 26, 2011 Some idea's I've had for testing: Taping the inside the box around the perimeter of the sub with duct tape. A test showing smaller speaker wire and bigger speaker wire. Different types of terminals between the amp and the battery. Like the knukonceptz one that you just stick the wire in and crank down the allen head vs soldered ring terminals. Also, try inserting a termlab in a box and taping it shut. Then addressing to send it to.... I kid Keep up the good work. 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router.
BigPimpin91 Posted April 26, 2011 Report Posted April 26, 2011 Also, try inserting a termlab in a box and taping it shut. Then addressing to send it to.... I kid :lol: :lol: BigPimpin91's Banging Music
STEvil Posted April 26, 2011 Report Posted April 26, 2011 pressure points are near sub and near port entrance inside the box. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
