help pleasee, amp cuts offf need info about power supply...
kk....
Theres 2 problems for me now..... finding a cheap yellow top, and SPACE! major one is SPACE, my enclosure takes the whole of my boot, and i dont have any space what so ever..... Ohh, im thinking about taking out the spare tire,
lol i just brought a EQ  of ebay.... :D
you can throw the battery where the spare tire is.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Dham i just couldnt resist, I got my self another JBL 1201.1  1200 Watts RMS, and at the moment im pushing 2400 Just off 4 gauge wiring, Now that created LOADS more problems,
i now need anothe run of 4 gauge minimum to the second amp as pulling it from the single cuts it off....
I DEFO need yellow top in back now... and im going to change the stock battery.... hopefully that should sort stuff out, but man now i got the 2 amps, wiring looks terrible.... i defo need some advice ideas on how to keep it clean.. also pics would help loads!  ;)
advice u say? get rid of the damn amp till u get enough power to run it be4 u fry something possibly both amps
well, we tried to warn you...  :-X ...anyways, YOU NEED TO BEEF UP YOUR ELECTRICAL BADLY, as with most beginners this is an oversite and sometimes leads to bad things... i.e. fires, fucked up amps and such. as for keeping your wiring clean, just run the wire underneath the carpet and wire tie everything, its really not that hard, it just takes time
i likes me some audio stuff...
man get you some 1/0 gauge and fuse that bad boy with a 300 amp fuse and put your extra battery in the back and fuse the 1/0 gauge before the 2nd battery. you'll be good to go man, forget adding another 4 ga. that's useless with that much power.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
you do what we've recommended and you'll be well on your way broham. i like the kinetic junts too or either batcap, either or will do a great job. good luck
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 1447 Guests (See full list)
