Help With Strapping AQ3500's Impedance...
I run mine .5 ohm strapped when I burp ONLY!!! Still get some volt drop as seen in this video, now granted my xs batts had been sitting for like 3 weeks and were low, but still with the quad alt kit under the hood, 900+ amps of current out of the alts, still got some drop and they won't play music at .5 strapped, just burp.
Thanks...i'm not looking to burp at all. I'm building the biggest wall possible tuned at around 28-30hz, so I'm looking for deep bass. I just have had an AQ2200 running daily music on .5ohms, and I was hoping that the AQ3500's would be able to do the same. I know the AQ's have had issues with the vertical mosfets breaking, and AQ not warrantying it, so I guess I don't wanna go with too much power, and have too many problems.
Well it can be done even with as little as 2 D3100's and 1 D3400 and one 220 amp alt, I did for about 1 month competing, only went to two shows like that, but still they held together, you drop to 10.5 almost instantly tho...LOL
LMAO.. see my point..
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
I run my DDs at .7 strapped (aqs older brother) play music all day. i can get my slave amp to protect on me during real low bass (probably cuz its mounted on the box) but i can play music in the 52s to 53s also. Oh and i do drop to high 12s during a burp. but stay in the 14s during music.
Edited by dc98hoe
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Yeah but there is a pretty big difference in going from one amp at .5 ohm and a 3k amp at that to two 4k amps to .25 ohm each. They pull lots of current!!! And I tried to play music thru mine at .5 ohm strapped and they played for about 15 sec and then went into overcurrent mode as soon as the note changed, into protect mode and the whole time my voltage was in the 13's.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
But aren't your DD's modded?
Evo X build log
no no no, i'm not gonna have them at .25ohms each...I plan on running them at .5ohms each, being 1ohm strapped. I wouldn't think of going .5ohms strapped on music.
yea if you need more power sell the aqs and look for something different.. maybe sound digital? cactus sounds?
yea but i always had them wired like that they did protect more on music before. so i guess you are right. lol
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I got ya now, I have no idea, i know they run all day at 2 ohm strapped and I have heard they do fine at 1 ohm strapped, so I don't know.
Evo X build log
Can't...trying to please some sponsors, and get more, so I gotta use what they suggest. I guess I'll just go with the 2ohm strapped, and run em' like they are supposed to be.
  • Who's Online   1 Member, 0 Anonymous, 1328 Guests (See full list)
