Just playing the normal ole' music.. and i hear a weird... OOoOooooOOoooOOO... idk.. sounded kinda like a weird horn noise... wasn't too loud, but was annoying..
Any ideas ??
Any ideas ??
is it like a whine or, an elctrical sond?
Double check your grounds. A trick I saw is to wrap a stripped speaker wire around the shield on your RCA's to a grounded screw helps get rid of engine noise, either that or a ground loop isolator. Try hooking and unhooking different amps if you have more than one.
POTATO!
you checked all of your grinds in under a minute?
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
Any ideas ??
Try grounding somewhere else. And get it as short as you can to the chassis. Also if you're running more than one amp, make sure they ground to the same place or as close as possible. This will help eliminate ground loops.
**EDIT if you have slack in your RCA cable, don't wind it into a circle, zig zag it if that makes sense, a loop of wire forms an inductor which will capture radiant noise.
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
no i checked it when the noise was coming on... all the ground were good but haven't had another problem sincepardon.gif
  • Who's Online   0 Members, 0 Anonymous, 5036 Guests (See full list)
