How To Properly Fuse Amps and Rear Batteries
Did it Help
34 members have voted
  1. 1. Did this Guide Help You?
    • Yes - Thanks :D
    • No - Still Confused :( (Post Why So I Can Help)
    • Didn't Need the Help (Already Know How)
    • I am stupid! Why am I here?
First off, you need to be comparing apples to apples, not oranges, every situation will require a difference in configuration, as is electricity is a strange thing, that is why alot of electrical study is theory and not law, all you got is ohms law, that is the one that is trusted. Electricity is effected by many things and time is just one of them. The point being current has to originate from a source, that is the enemy in dead short, which is what a fuse is to protect, protect the equipment in the event of a short to ground. Current starts at the source, the battery, this is why you want that damn fuse as close to the battery as possible to avoid, one, a short between the fuse and the battery, this is accomplished by putting the fuse less then 18 inches away, but the closer the better. And two, fuses are time delayed, all fuses are, just some are slow blow and others are fast. But electrical components will handle above there rating for a given time,,,HOW??? Temperature changes conductivity. So point being placing another fuse by the amp, it is pointless, the amp is not the source of current on the input, it is the demand, how can it short out a fuse if there isn't a short on the line that is already protected by one fuse by the source, the battery? It can't.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
The other point being this is dc power we are talking about this can't be applied to AC, which some people confuse. Current is one way in DC, direct.
Evo X build log
there are only ever 2 issues in electricity...only 2 ...
either there is a connection where there shouldn't be one...or there is no connection where there should be one....that's it. those are the only two issues EVER
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
and you have to factor in parts failing, which I guess leads to your idea again :D
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
In DC yes, AC no. LOL
Evo X build log
2 different beasts
Pioneer 4300DVD
ultimately it leads to these two issues
Principal
Frequency dip or voltage collapse don't always cause either of those.
Evo X build log
but, usually, neither of those is catastrophic, either
Principal
And what happens when your phase angle is more then 45 degrees out of phase and you try to reconnect an open line? LOL
Evo X build log
