How To Properly Fuse Amps and Rear Batteries
Did it Help
34 members have voted
  1. 1. Did this Guide Help You?
    • Yes - Thanks :D
    • No - Still Confused :( (Post Why So I Can Help)
    • Didn't Need the Help (Already Know How)
    • I am stupid! Why am I here?
Alright thanks
when I had my van I never ran a negative to the front, I just drilled a 3 inch hole in the floor of my van, and ran two 1/0 gauge right to the main frame rail which runs right up to the front, so I was set :D but the only down side is you now have a huge hole in your car, ha ha
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
whats a fuse?
are you being sarcastic I hope :ehh: if you dont use one this happens to your car =@ and I do this :popcorn:
Pioneer 4300DVD
Wait... Do you have to ground the rear battery to the front battery negative or could you ground it to metal or chasis in the back?
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
either, just needs to have a ground path back to the alternator ground, which is basically the engine block and everything around it, so you can go right to the frame and be fine as long as your car frame is mostly one piece
Pioneer 4300DVD
From what I've read the reason for the negative run from rear battery to front is that its more efficient than the spot wields along your frame. As for the fuse its best to put it on power line near each battery in case of short the fuse closest to short hopefully catches it.
the only fuses i used is to my 4500 anythind else is realy unessasary. running all those fuses is just costing u resistance. No bodys grounds in my vehice gained .8 db so yea
Youtube.com/J Hutch22
thanks for posting this man i am about to hook up my back battery this weekend and this will be something i can look at and double check my work...thanks!!
id rather listen to no music than music without bass-zayres29
My youtube vids
My Build Log
no problem! Glad it helped, I might update it soon to make it look a bit cleaner :D
Pioneer 4300DVD
I dont know how your setup is, but as long as its fused by any batteries you eliminate 90% of the risk
Pioneer 4300DVD
