This is the build log of my car, a TCDi Ford mondeo Estate,
Before we begin - sorry the pics are not embedded but the forum software wont let me
Firstly the car - a 2004 Mk3 Ford Mondeo Diesel
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=23628
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=23616
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=23612
All normal and boring so far - btw did you notice the steering wheel on the correct side ;)
now the kit list
Now for what is happening it it
6 batteries in the boot
2 1kwish audio system amps for the front speakers
1 3kw massive audio amp for the subwoofers
8 JL Audio 12inch woofers
no rear seats
6.5 inch speakers in the kickbuilds
tweeters in the a-pillars
8inch midbass speakers in the doors
So off the car goes to my friends bodyshop for the work
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26278
Blacked out windows
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26283
Stripped interior for deadening
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26291
Loading wall put inplace to make sure drivers seat goes into position
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26309
Carcase of the enclosure started
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26375
more work on the carcase
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26392
Location of one of the frontend amps (other on the other side of the box)
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26432
Woofer baffle in
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26470
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26478
Woofer baffle detail
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26482
back of the box
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26617
Stock suspension coping well
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26653
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26629
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26621
I do have uprated springs for the car but the stock stuff is staying on during the build
Fibreglass matt and resin to add to the enclosure strenght
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26637
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26641
Front of woofer baffle
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26649
That is all the work that has gone on so far, need to get to my friends bodyshop to see the current progress - my friend who is building this car has previously built this - http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26440 so i have a feeling it could be interesting
i LIKE this! very interesting way you did the wheel wells
its not be building it but they were built as follows
The car hs to be able to be put bac to stock so no fibrelass straight to the metal of the car, instead a layer od masking tape was put over the entire car and then amixture of bodyfiller/fibreglass was layered over, small squares of MDF were cut and embedded in the bodyfiller/fibreglass mix -- then another layer was put over - makes it very strong but gives the maximum space for the enclosure
and these are the woofers going in
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=22813
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=22827
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=22831
  • 4 weeks later...
Now an update with pictures
First the back of the car
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26692
As you can see the box does come a fair bit back but i should get my weekly shop in stiff - if not its an estate so has factory fit roof-rails, in this pic you can see the epic, crossover for the two front amps, some of the batterys (the others are below the enclosure) the sub amp and the distribution/wiring
Looking through the drivers door with the seat reclined
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26688
Nice shot of the woofers looking in :D
A very tight tolerance in the woofers - notice how the centres overlap slightly
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26664
A better shot of the overlap
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26668
Nice neat work in the enclosure
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26672
Rear shot of the woofers, notice the steel re-enforcing the port edge
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26680
Close up shot
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=26676
It has been playing so we know that it works
The playing was a just a test run to make sure it all worked, the amp powered up as it should, all the woofers looked to be moving the same distance but for the volume they were barely twitching, the test run was just off my batterys that were floating at 13.08v at the beginning of the test, after a good 40mins of mild thrashery (only mild as naff all is setup or configured) but the amp did not get warm and the batts only dropped .58 of a volt
The enclosure does not look like it needs much more work tbh as it was playing most of what we threw at it so it will be interesting to see how it gets once everything is setup correctly, we have already had minor steering wheel wobble but it just sounds infinatly more evil than the boot installs of the past, we were expecing Rich having to extend/make a port for the rear chamber but it seems to like playing most of what i listen to (And Rich had a huge amount of fun going through the USB stick of random music i listen to) but the proof will be when the crossovers and epic are set, gain matched and its not just running off battery power
The reason i have not shot vids is that it is not finished yet, it was just a test to make sure it was working
Plus i only had my SLR with me, not my video camera - if i remember tomorrow i will take my video camera
Right update time
Both the passenger and driver doors have had the doorcard and door lining removed awaiting some Loudboy deadening
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=27020
The 6.5 inch mids have been mounted on wood and then mounted to the speaker bracket ready to go back in the door
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=27025
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=27030
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=27035
And a big hole in the spare doorcards
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=27040
The big hole is for these
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=27045
http://samuelellis.cozywebhost.com//gallery2/main.php?g2_itemId=27010
Kicker RMB8inch Mids - old skool now as they were made in 2002 but as far as i can tell never out of the box until i got them a couple of years ago and have never been powered up
The 8inch mids are having a small enclosure built around the back of them so they dont fight for airspace with the 6.5's
Its getting close to time when we can power it up properly, set the crossovers etc and actually get some readings on the meter
  • Who's Online   0 Members, 0 Anonymous, 5023 Guests (See full list)
