Mechman Alternators
need sum juice
hey lookin for a alt @ bateries for 2000 suburban to power sa3500(1)and (3)sa100.4 got any thing for me?
270 amp ES unit
165 amps at idle
full output by 1800 rpm
custom solid copper rectifier
oversize terminals
overdrive pulley
$449
350 amp SMD unit
190 amps at idle
oversize terminals
overdrive pulley
$675
I always recommend the D1400 14 volt batteries for the Sundown amps. You would only need two the the SMD unit, 3 bats with the 270 amp unit. They are $259 each, and will fit in your stock battery location. That setup will keep you in the high 14 volt, low 15 volt range at full tilt.
regards
Matthew
