Well i just got a kinetic 800 used off ebay for $85 shipped. I want to charge the battery befor i put it int he car but according to the kinetic site they say to use there charger or a special kinda of battery charger. Can i just a regualr 12v car charger? Has anyone else done it?
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
actually after "seeing the light" i would either use their charger or the PowerMaster charger like i have. There IS a difference and my roll-away can roll off into the sunset for all i care.
Follow my Tweet (Twitter)
HHmm well in that case would i be better off just putting it in the car and let that charge it? There chargers are to expensive.
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
nahh if you HAVE to use a regular charger then go for it, just dont get it boiling too much. Trickle charge it over nite. Dont rely on your alternator to charge the battery like that, in fact if the battery is even a little low it is VERY bad for the alt.
if u ballin like meade :D definitly go with the special charger. po folks like me havent had a prob with a standard charger starting off at 10 amp charge then cycling up and down to 40amp. either way i would charge it because it might take quite awhile to fully charge off a stock alt.
im not ballin YET bro :D workin on it :D
the only other way to get it charged is to know someone who works at a local audio shop or auto shop with a battery charger who wouldn't mind charging it for a lil piece of change.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 573 Guests (See full list)
