very nice meade
i love the digital gauges that is sick
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Guest Nismofreak
steve so what sequence you need to use for the subs......cuzz that is a big amp?
your gonna wire each sub at 2 or 1 ohm?
That thing is OFF THE HOOK
I liked the end haha
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
8 subs, dual 2 wired in series each.....so 8 4 ohm subs. Each side will be paralleled back down to 1 ohm and put on either the front or rear depending on the side and bridged. 1ohm bridged means the amp will "see" 1/2 an ohm. Make sense?
basicly a series parallel config....
Follow my Tweet (Twitter)
Guest Nismofreak
got it thanks
How much power do you think it will put out at .5 ohms? Also.. do they have like the link so you can link the two amps and master and slave? (I seriously wouldn't be suprised if they didnt, and madd props if they do because I think you'll be the only person in the world for quite a while with 2 of these bamf's)
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
no need for a master slave link, one is playing bass the other is playing mids/highs...... ;)
at 1 ohm bridged i should get full power out of the amp.
thats a complicated wiring job
sounds like fun man
wut ohm are the subs VC's
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
:huh::huh::huh:
Woah... I musta missed that in the build thread.. thats INSANE
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
