Mechman Alternators
Chevy Blazer 4.3L Alt
300 amp Rev series
8o amps at idle
300 amps by 1800 rpm
Solid copper rectifier
oversize terminals
zero gauge cable ends included
overdrive pulley
$449
350 amp SMD spec unit
190 amps at idle
full output by 1800 rpm
oversize terminals
overdrive pulley
$675
425 amp Comp series
40 amps at idle
oversize terminals
overdrive pulley
SALE PRICE - $449 (Reg. $675)
Edited by MECHMAN
Are all these fine for daily use?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
40a at idle is leaning more towards no, but the other 2 are good for daily.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
300 amp Rev series
8o amps at idle
oversize terminals
overdrive pulley
$449
190 amps at idle
oversize terminals
overdrive pulley
$675
425 amp Comp series
40 amps at idle
oversize terminals
overdrive pulley
ook soo if i have dUAl alts can i use the the 425 comp alt as my secondary? its on my daily driver!
"yes... it will play like that all day!"
I only run a single 425 amp unit on my silverado. It is my daily driver, and I have driven it that way for 2 months now. Aside from having low voltage at idle, I have not had a single problem out of it. When I turn the stereo up driving down the road, it slows the truck down, LOL. It holds great voltage, even with 4KWRMS as full tilt as I'm driving down the road. If you don't mind revving when you demo, it's a great unit to go with.
  • Who's Online   1 Member, 0 Anonymous, 1707 Guests (See full list)
