ChampN252 Posted January 29, 2011 Report Share Posted January 29, 2011 I've read that with turbos, mileage can sometimes drastically improve. I mean with the engine you put it on. Anybody know anything about this? I've read that's one reason newer fuel efficient cars and SUVs have small 1.0 and 2.0 liter engines with turbos. Quote 2012 Honda Accord Radio: Pioneer AVH-4200NEX Link to comment Share on other sites More sharing options...
zayres29 Posted January 29, 2011 Report Share Posted January 29, 2011 when you arent in boost turbos atomize the air which creates a more dense charge of air entering the engine allowing fuel to burn more efficiently so yes you will see better mileage but that is only if you can resist keeping your foot out of it Quote Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged Link to comment Share on other sites More sharing options...
C-Fizzy Posted January 29, 2011 Report Share Posted January 29, 2011 If you floor it (which you'll want too) you will drastically lose mileage. Quote under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy? Link to comment Share on other sites More sharing options...
ChampN252 Posted January 29, 2011 Author Report Share Posted January 29, 2011 (edited) double edged sword, I see. I read that 5 or 6 lbs is the prefect balance of power and mileage. Edited January 29, 2011 by ChampN252 Quote 2012 Honda Accord Radio: Pioneer AVH-4200NEX Link to comment Share on other sites More sharing options...
cOmpressor Posted January 29, 2011 Report Share Posted January 29, 2011 when you arent in boost turbos atomize the air which creates a more dense charge of air entering the engine allowing fuel to burn more efficiently so yes you will see better mileage but that is only if you can resist keeping your foot out of it Isn't air "atomized" naturally? Turbos will not help with gas mileage in that sense. For daily driving you will use more gas doing thing like getting on the freeway and hill climb. With a turbo the engine runs more efficiently and can produce more power with less effort in those situations, thus using less gas. As cruising/freeway is concerned, it will not make any difference + or -. Quote Link to comment Share on other sites More sharing options...
zayres29 Posted January 31, 2011 Report Share Posted January 31, 2011 when you arent in boost turbos atomize the air which creates a more dense charge of air entering the engine allowing fuel to burn more efficiently so yes you will see better mileage but that is only if you can resist keeping your foot out of it Isn't air "atomized" naturally? Turbos will not help with gas mileage in that sense. For daily driving you will use more gas doing thing like getting on the freeway and hill climb. With a turbo the engine runs more efficiently and can produce more power with less effort in those situations, thus using less gas. As cruising/freeway is concerned, it will not make any difference + or -. i read a big long write-up on turbos and gas mileage and the article said that even at highway cruizing the will see better gas mileage due to the fact that the air still has to be run through the turbine its the same effect as putting one of those tornado things in your intake i mean there isnt like a 5mpg difference but maybe 1-2 Quote Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged Link to comment Share on other sites More sharing options...
